Results 1 to 8 of 8
Thread: can i run all this on a 90w opus?
    Jan 2004
    Minneapolis MN
    i have a M10000, full size dvd rom, full size hdd, in a 2699 case and i'm wondering if the 90w opus i have is plenty to power it. Im hooking up my lilliput to the car not the opus so i wont need to power that. i know i saw someone on the boards that had a similar setup and still ran a lilliput to their 90w opus and didnt have any problems but im just making sure. thanks for the help
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Using the wattage calculator your setup* needs about 68 watts for peak usage (DVD playback), so you should be OK.
    * I assumed a 40mm fan and a couple of USB devices.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    check the requirements on your devices.
    I believe the M10K mobo will draw like .86A on 5v and .2A or so on 12v
    add up all your power requirements.
    such as my laptop hd draws like .80A, my dvd drive (external) pulls 2.0A at 5v..etc.
    Mine needs to be updated.
    Aug 1999
    Washington D.C.
    You should be fine with that setup.
    Constant Bitrate leenas's Avatar
    May 2003
    Right now im powering on my 90w.
    M10000
    USB Touchscreen
    USB Remote
    Serial GPS
    Digitalww 7" Screen
    Keyboard
    2.5" Solid State Hard drive
    3.5" 30 gig 7200 RPM hard drive
    and sometimes just for fun a slim dvd drive with IDE to usb adapter.
    I havent really run into any power issues. It will sometimes restart with the dvd drive but i think its more cause of the way its wired than actual too much power being taken up.
    Mar 2004
    Quote Originally Posted by leenas
    M10000
    USB Touchscreen
    USB Remote
    Serial GPS
    Digitalww 7" Screen
    Keyboard
    are you using one of those 704mb solid state hdds? if so, are you using it for your OS, and how fast is it booting up?
    May 2003
    yes, windows 98, under 40 seconds from power press to music
    Hardware: M10000 / 2.5" 700meg Solid State Drive / 30 gig 7200 rpm HD / DigitalWW 7" LCD / USB Touscreen / X10 Lola Remote / Serial GPS
    Current Project: Turning Nissan Steering Wheel Remote into Joystick to control Frodoplayer
    Low Bitrate Insight's Avatar
    Quote Originally Posted by pip
    On this calculator there is not room for ram, is that included someplace in the calculation?
    CarPC
    VIA Nehemiah M10000, 256MB RAM, 40GB HDD
    100W DC PS /w ITPS, TV tuner, Slim Slot-Load DVD
    GPS, Streets and Trips 2004, Rearview Camera
    Bluetooth, 802.11b & CDMA 1X
    In-dash 7in Lilliput Touchscreen
  1. Opus 90w, heat problem and the heatsink
    By samc in forum Power Supplies
    Last Post: 04-19-2004, 09:07 AM
  2. wiring question about the opus 90w
    By DSM97RS in forum Power Supplies
    Last Post: 03-28-2004, 09:28 PM
  3. Opus 90w Power Action
    By EBoundEE in forum Power Supplies
    Last Post: 03-10-2004, 10:11 PM
  4. Opus DC-DC 90W 150W Pricing Dimensions Info
    By Linus in forum Power Supplies
    Last Post: 10-15-2003, 04:29 PM
  5. Opus 90W: PCB module or Open frame?
    By dormouse in forum Power Supplies
    Last Post: 10-01-2003, 02:04 PM
