In the manual for the power supply, there's a page where it lists a bunch of settings the BIOS needs to be configured for. Did you set every one of those? There are things in there like auto-power on that must be set properly.
I got some questions about the wiring and setup
My Opus 90w came with red, black and blue wire.
I connected the
red to battary with fuse 10.
black to ground
blue to cig lighter(tap into the lighter) Add a on/off switch in between.
I am using VIA EPIA 800.
I can shut down the computer, my ign also shut down my computer BUT it will start up after about 2 seconds...by then, I am already out of the car.
The switch I added does not seem to work.
where did I go wrong?
Is the EPIA M-series setting and EPIA setting same? I got M-series instruction from Kris but I am using EPIA 8000. There is slight different in the BIOS. I tried to follow as close as possible even thou it is different. Let me go look into again.
This morning I went down and found the computer is still on. It was running the whole night.
