Results 1 to 4 of 4
Thread: xBox Power Supplies
    Low Bitrate crosseye's Avatar
    Dec 2003
    Syracuse, NY
    xBox Power Supplies
    I was thinking about possible small, lightweight AC-DC power supplies for in car PC applications. One of the smallest and cheapest power supplies I have run into is the power supply for a Microsoft xBox.
    The power supplies seem to have an ATX connector and 1 power connector for an IDE device. Might be suitable for some people's PCs.
    Does anyone know the output Watts from these units?
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    they use 100 watts max load i believe
    '98 Explorer Sport (down atm)
    80% done
    Jan 2004
    I wouldn't be surprised if the pinouts on these powersupplies are different than the standard ATX pinout. Some DELL computers use different pinouts although they will connect to regular boards. If you do connect these powersupplies to non-dell boards, they will **pppzzz ZAP**
    I would check on some X-BOX mod sites to see if they pinouts are the same.
    Jan 2004
    Canberra - Australia
    You'll find the pinouts different.
    In an early Sproggy thread myself and a couple of others go into some detail about the differneces...
    For a start there's no -12 on the Xbox. (makes sense becuase there's no legacy)
    It powers on differently, it power OKs differently...
  1. Load Balancing Power Supplies
    By strandtc in forum General Hardware Discussion
    Last Post: 04-16-2004, 06:42 AM
  2. key power power supplies
    By Sway in forum Power Supplies
    Last Post: 04-03-2004, 09:26 PM
  3. Store carrying OPUS Power Supplies
    By Zip-Lock in forum Classified Archive
    Last Post: 02-24-2004, 10:39 AM
  4. dc-dc 250 watt power supplies
    By dscustoms in forum Classified Archive
    Last Post: 05-30-2002, 01:05 AM
