Results 1 to 4 of 4
Thread: Source of high-output alternators?
    May 2004
    Question Source of high-output alternators?
    I currently have a '99 Mitsubishi Galant ES V6 and I believe it has a 90A alternator. I've seen 120A high-output alternators for older model Galants but have not been able to find one for my particular model.
    I was hoping someone out there might know of a place which might have such a beast since I know the addition of a second battery bank soon to my vehicle which will be deep-cycled relatively often will definitely put a strain on my 90A alternator. And the last thing I want to do is burn it out.
    Thanks in advance for any help, comments, suggestions!
    [Note to Moderators: Sorry if this is in the wrong forum, but couldn't find a better place for this question. Feel free to move/delete if inappropriate.]
    Maximum Bitrate falconey's Avatar
    Feb 2004
    I believe there's a place on the net called Ohio Generator or something like that. Use that name and google it and you may be able to find something. I didn't know they had Galants that weren't 4 bangers. I guess this is why Diamantes aren't selling for sh**.
    Not sure if they make 'em for Mitsubishi's though.
    Good luck.
    May 2004
    I just e-mailed Mean Green. I didn't see it in their catalog. Looking up Ohio Generator now.
    Also, I currently have an Optima Yellow (D34) top battery as the main car battery which is 55Ah. I will also have 110Ah battery-bank that will be isolated by a battery isolator. There are times where I know the 110Ah battery bank will be completely drained (to about 10.4 volts).
    How much stress do you think I would put on the factory 90A alternator if I didn't put some type of multi-stage alternator regulator or a higher-output alternator? I see that Xantrex makes a multi-stage regulator for alternators (and supports Optima batteries, on top of gel, AGM, etc).
    Last thing I want to do is burn my alternator out.
  1. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 03:48 PM
  2. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 12:19 PM
  3. Car Alarm Aux output and Shutdown controller
    By MatrixPC in forum Power Supplies
    Last Post: 05-09-2004, 08:36 PM
  4. Is ME open source?
    By SuperG35 in forum ME Archive
    Last Post: 08-22-2003, 03:42 PM
  5. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
