Results 1 to 10 of 15
Thread: MiniITX VIA TC-10000 w/ 12V DC-DC built in
    I was just reading the review on the VIA MiniITX TC-10000 at http://www.techseekers.net/modules.php?name=Reviews&rop=showcontent&id=76 .
    It apparently has a 12V DC-DC built in to the mobo. I checked the spec of the DC-DC converter http://www.viavpsd.com/product/3/4/epia-tc_v120.pdf .
    It mentioned that the Input is 12.6V MAX and 11.4V MIN. Now I know that the voltage fluctuation from the alternator can exceed that.....
    What do you guys think? It would be great to save ~150 bucks on an opus if this works...but I don't think the DC-DC converter on board might not be able to handle it....
    Mar 2004
    ok you saved on powering the mobo, what about your HDD, DVD and so on. You still need a PSU.
    Never be afraid to do something yourself. Remember - amateur built the Ark, professionals built the Titanic.
    Quote Originally Posted by arkadiyp
    check out the spec of the mobo and the review...it has multiple voltage output on board.......
    FLAC Chairboy's Avatar
    Jan 2004
    It powers HD, floppy, optical, etc. Did you read the article?
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    oh
    my
    god.
    Thats friggin awesome. it uses laptop ram. it has a PCMCIA slot. Compact Flash. 6 USB ports.
    and its available now for less than $200.
    It is a pity that you cannot boot from the CompactFlash adapter.
    just wanted to throw that in there incase anyone missed it.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    12.6V max and 11.4V min may not be sufficient for a car computer. Altenator voltage is usually 14.4V and when cranking the electrical system drops to below 10V.. then again you might be lucky and it might just work regardless
    Jan 2004
    Norway
    I'm quite sure I read somewhere that these boards don't regulate the 12V line. In other words, it's about the same as a M10k plus morex or pw-70 psu. Please correct me if im wrong.
    May 2004
    Surrey, UK
    OK I'm a bit new to all this.
    I'm mounting a liliput screen in the car at the moment. Now I'm looking for a MinI ITX.
    I had decided to buy an Opus 90w as well. If I bought this MiniITX, I wouldnt need the Opus?
    Would it restart on Crank? Could I just connect it direct to the battery, with an inline fuse?
    Jun 2000
    Nashville
    starfox, you would have to get a 12v regulator just like for the PW70's and Morex PSUs
    riddster, it probably wont survive the crank without a tank circuit, and you can't use an opus because there is no ATX power connector.
    I think I'm gonna buy one
    I'M DEBT FREE!!
    May 2004
    Surrey, UK
    I'm going to get one as well. Can you recommend a good cheap 12v regulator to use with it?
  1. What about 12V DC Outlets that are built into the car?
    By mr_anderson in forum Power Supplies
    Last Post: 01-14-2004, 03:22 PM
  2. Replies: 5
    Last Post: 08-20-2002, 08:32 PM
  3. why not to use zener to make 12V DC??
    By embedded in forum Power Supplies
    Last Post: 04-26-2001, 08:54 PM
