Results 1 to 9 of 9
Thread: Via TC 10000(onboard 12v) - In car installation
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    Hi Guys
    I am still a little confused after talking on some other forums....
    I am looking to buy a Via TC 10000 motherboard which has the onboard 12v dc-dc power, and i want to install it into my car.
    Now as far as i know, i need to regulate the power from the car battery/alternator. This I assume can be handled with an ITPS.
    However, is there something I am missing? These OPUS power supplies everyone keeps telling me to buy are really expensive, so what do they do that the ITPS & 12v dc-dc dont?
    Any help would be great. If these TC 10000 mobo's are limited then I might get a MII 12000 and an opus, but it works out at nearly double the price!
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    get the ITPS and that TC 10k board..
    Mine needs to be updated.
    zvi
    zvi is offline
    Constant Bitrate zvi's Avatar
    Jan 2004
    Tbilisi, Georgia
    Opus will secure crank surviving, ITPS not.
    It is a matter of what is the range of input voltage of particaular power supplies, OPUS inout range is enough to work in any situation, as extrem as cranking even, I don know what can you use to feed TC10k's 12v, you have to seek for DC-DC power supply that gives 12v (and enough current) from range like 7-16v. Or, just take 90 Watt Opus and M10K or MII
    '93 Opel Vectra A with Custom Dash with 7" lilliput
    VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
    http://zvi.home.ge/pics/?dir=vextra
    May 2004
    Somewhere in the UK
    Could you explain cranking a little more?
    Do you mean power surge when ignition is switched on?
    May 2004
    Somewhere in the UK
    Here is another question:
    CAN the ITPS be used with the TC 10000 mobo?
    The ITPS has a different connection in and output, and the TC mobo has a standard mini-jack type socket. (Forgotten the name :S)
    Any ideas?
    CHeers
    Jan 2004
    'cranking' is when your start your car... the alternator (i think) uses power from the battery... which starts the engine... and it does something to the power (battery)... so u wont have enough 'juice' to have the cpu running
    i dont know a whole lot about cars... but i think thats a general idea of how it works, when you start your car
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    Ok so in my car i have set up a epia-m10000 mobo(motherboard) with a pw-70...and i have a regulator....not itps, which controlls shutdown, but just a regulator......
    I have to build a "tank" to survive the crank...but it could be that i am using the 12gauge wires..i think that is really the problem (since when i measure the voltage of the baterry at crank it doesnt go below 10v)
    SO: here are the options:
    1. [BATTERY]----+---->[opus]----->[Motherboard]
    2. [BATTERY]----+---->[itps or regulator]------>[pw-70]--->[motherfu*** I MEAN board]
    May 2004
    Hollywood
    UPDATE for #2....if you want to survive the CRANK:
    2. [BATTERY]----+-->[tank]-->[itps or regulator]------>[pw-70]--->[motherfu*** I MEAN board]
    now help me find a tank...I seen people build it...but i am no electrical engineer
    Jan 2003
    "Cranking" is when you turn the ignition and the ignition motor drives the flywheel of the car. It takes a lot of the batteries power to move the flywheel to initialize the car starting... it has nothing to do with the alternator... the alternator doesn't work until the car crank is spinning. Basically, you want a ITPS because it will delay the point in which the computer will start.
    Say the ignition system pulls some nasty power from your battery... the battery (12v @ 100% since the alternator isn't running.. but you can expect 11 - 11.8V typically) voltage will drop considerably. Sometimes down to like 7 - 9volts. If the computer tries to start on an input voltage of 7 - 9 volts, it will fail. What the ITPS does is all a time buffer, because once the car is running, then the alternator is spinning and "should" be cranking higher voltage than 12v of the battery... commonly 13.8 - 14.4 volts. So, think of the ITPS as a "delay" valve for the power to rush into the computer.
  1. can I power a car stereo with an ATX PSU?
    By Fourgig in forum General Hardware Discussion
    Last Post: 09-08-2009, 07:40 AM
  2. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 10:11 PM
  3. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 01:47 AM
  4. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
  5. god damn university car regulations
    By MikeHunt79 in forum Off Topic
    Last Post: 09-27-2001, 12:02 PM
