Results 1 to 5 of 5
Thread: 6 amps running prime95
    I bench tested my setup today. It's a single board computer with an onboard LCD controller, a pentium 3 800, 256 megs pc133 , 20 gig 7200rpm hard drive, a teac notebook cd-rw, and a 12" LCD. I'm using a 250 watt AT power supply run off a 400 watt inverter.
    The current draw was much lower than I thought it would be. The inverter pulled 4 amps at 12.4 volts when the rig was idle. i ran prime95 and when the cpu was loaded it pulled 6 amps at 12.2 volts. That means the whole rig only pulled 72 watts at full load!?!?!? 72 watts at the battery?!?!?!?!
    could this be true?
    Nov 2003
    Apeldoorn, Netherlands
    thats low, but a p3 800mhz doesn't draw much "watts" (20.8watt) and your lcd wont draw more then 20watts orso, so it could be possible yeah
    Newbee, sorry for my bad english. lol
    Trying to built a carmp3 systeem
    own psu: max788, pt5071, pt5024
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Doesn't sound completely unreasonable. My P233MMX setup draws about 2.5A under load with a VFD.
    I figured stepping the voltage up to AC and then back down to dc would have killed the effeciency.
    May 2004
    Efficiencies are heavily dependent on the brand of inverters and also what you are powering. I've seen some DC-AC inverters as low as 70% (no-namers and cheapies) which claim '90%' efficiency and some which work as advertised near 93%-95% efficiency. With inverters, you do get what you pay for.
  1. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 10:11 PM
  2. Running Two Computers?
    By dapilot in forum Power Supplies
    Last Post: 04-15-2004, 09:14 AM
  3. Anyone running their computer AND amps off the Opus?
    By brrman in forum Power Supplies
    Last Post: 12-09-2003, 02:30 AM
  4. Replies: 9
    Last Post: 11-01-2002, 12:21 PM
  5. Questions about running cable, also powering questions
    By dudah85 in forum General Hardware Discussion
    Last Post: 05-31-2001, 10:36 AM
