Results 1 to 4 of 4
Thread: hard drive and dvd watts
    Jul 2003
    houston tx
    how many watts does a regular hard drive and dvd player take up. i am planning running a laptop and want to know if i can run a regular hard drive and dvd drive on a 60 watt power supply
    Jul 2003
    houston tx
    anybody. i would like to know if i can run a full size hard drive an dvd drive on a 60 watt power supply without a motherboard hooked up to it
    Sep 2003
    Virginia
    If you have the drives, look on the label. Most have the amp draw on it somewhere. It's going to vary quite a lot from one drive to the next. I have a WD 10 gig that specifies 5v@0.68A (V*I=watts, so 3.5 watts) and 12v@.16A (1.92 watts) so the total would be 5.42 watts. I have a 40x sony CD-ROM that is 5v@1.0A, 12v@1.2A, 16.4 watts total. I have a DVD drive, but its in my computer, so I can't get the specs. I suspect it would be higher than a CD-ROM, but I'm not sure.
    Hope that helps.
    I would say that you shouldn't have any trouble run both off a 60 watt supply though. Just check the 5V and 12V ratings separetely. Even if the total draw is >60 watts, but the 12V draw is over the 12V supply limit, you will have problems. Also some power supplies don't like to run without a motherboard.
    Jul 2003
    houston tx
    thinkin about using a pw-60
  1. Need a short dvd drive
    By skippy_geek in forum General Hardware Discussion
    Last Post: 05-12-2004, 06:24 AM
  2. Slimline IBM DVD drive up for sale
    By mpattonm in forum General Hardware Discussion
    Last Post: 04-15-2004, 04:30 PM
  3. FS: Car Audio and DVD drive
    By bjm2020 in forum Classified Archive
    Last Post: 03-19-2004, 06:32 PM
  4. DVD Drive Question (slot loading)
    By breimann in forum Newbie
    Last Post: 03-09-2004, 06:20 AM
  5. dvd external enclosure drive
    By kuo in forum General Hardware Discussion
    Last Post: 03-07-2004, 05:36 PM
