Results 1 to 3 of 3
Thread: No more 5v on PW70A
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    No more 5v on PW70A
    Help I broke it
    My PW70A 5v rail no longer puts out 5v, it only puts out .83V, the 3.3 and 12v are all as they should be, what can I replace / upgrade to get my 5v back again, I am pretty handy with a multimeter and a soldering iron, but I havent a clue what has blown, I am thinking its an IC somewhere and what could I upgrade to, to prevent this happening again ?
    Help
    Thanks for the great info on my other issues in the other forums
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
    Oct 2003
    Maybe check the 78L05 chip. I believe that is a 5v regulator. I Just put a volt meter on mine and pin1 is at 5v when powered up.
    Just out of curiosity, Are you running the PW-70a without 12v regulation at all? I'm thinking of adding 12v regulation to pw-70a (similar to vvogs morex mod.) but to do it I would have to feed it mostly unregulated power. Just looking at the specs on all the chips now to see if it is feasible.
    If yours died being unregulated than I may have to re-think...
    Regards
    Feb 2004
    Quote Originally Posted by Shaky
    Regards
    Sorry for the delay in replying, been out of town, I will check the pin 1, I feed my PW70A with an ITPS, first the ITPS was regulating the 12v, then I did the bypass to remove 12v regulation as I was not getting enough power to spin up my desktop hdd that needs the 12v, even this didnt work as the drive wont spin up till it gets 12v (best i could get to the drive was 11.89) I changed to a laptop hdd and then I think i had too many 5v devices on the power supply so it burnt out the PW70A.......or I shorted something out....
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  2. Need more 5v....
    By sq_geek in forum Power Supplies
    Last Post: 05-13-2004, 06:53 PM
  3. Looking for a 5V Controller for LQ104V1DG11
    By SuperMatty in forum LCD/Display
    Last Post: 08-03-2002, 12:06 AM
  4. Something wrong, help need! : making -8V and 5V PS,
    By helloman in forum General Hardware Discussion
    Last Post: 04-27-2001, 04:51 PM
  5. need help on -5v power
    By noproblem in forum General Hardware Discussion
    Last Post: 07-11-2000, 12:37 AM
