These are the com port pin layouts
1 2 3 4 5
_________
6 7 8 9
I’ve been lurking for the pass few weeks trying to get some Carputer ideas. I’m also interested in trying out this shutdown method. How about using a Timer Delay/Relay instead of a capacitor? Would something like this work: http://www.smarthome.com/manuals/7279.pdfOriginally Posted by vcbb5
1 2 3 4 5
_________
6 7 8 9
Terran- I saw that too, but that would probably be expensive. I know there are ways to add a delay (i just have no idea how).
More links:
http://www.kpsec.freeuk.com/projects/timer.htm
http://www.astron.nl/~smirnov/poweroff.html
Jear but what stick on the relay shall i use?Originally Posted by vcbb5
Ok, I fixed a couple of bugs, so I put this up, if someone is interested.
http://ormkarr.cjb.net/files/shutdown.zip
The next step is to get the shutdown menu a little nicer maybe someone can make me one, perhaps in brushed metal style cause I´m using it right now.
Thanks alot... that will be very useful.
One thought: what if you made it so 4-8 only had to be closed by a momentary switch, and you made a softwhere shutdown timer? What language did you write it in? If you post the source code, I would give it a shot.
