Page 14 of 16 FirstFirst ... 45678910111213141516 LastLast
Results 131 to 140 of 154
Thread: Ghetto Startup/Shutdown Control for Inverter
  1. #131
    Oct 2005
    surrey bc
    my carputer is up and runing
    i have every thing working now but i had to make a change to the diagram a little this one is better and it works any way if anyone would like to see i will make a new schematic of what im using i would still like to build a nother one that has a timer but in the mean time this work exalent no hanging turn the key computer and amplifiers work and 2 5 inch lcds turn the key off and it proceeds to shutdown onece it has it turns itself off
    i hooked up a inverter to a home computer atx power suplly and through that i connected the laptop ,12 v 2 lcds 12volt all through the power supply witch also runs the 3 1/2inch hard drive that i made a 40 pin to 44 pin cable to adapt to the laptop i will now take some pics and post them soon
  2. #132
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by lexanite
    I just remind PatO that the drawing in Ghetto Startup/Shutdown Control for Inverter was wrong.
    1. The diode at the relay coil reverse connected.
    There will be no current flow at the relay coil because of the diode, means the current will flow through the diode instead of the coil.
    3. Current path missing: please explain at that drawing, how the current will flow from +ve battery through the relay coil.
    1) Thanks for pointing that out! I'm still learning this stuff... Taking that into account, are the LED's backwards as well?
    2) ??
    3) I posted the rest of the drawing on here somewhere... Oh - here it is! (sorry about pwning your screen's realestate..)
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  3. #133
    Oct 2005
    surrey bc
    pics
    heres some pics more tommarow
  4. #134
    Jul 2005
    Jakarta
    PatO,
    here some correction to your attached diagram. Please see the attached drawing.
  5. #135
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    PatO,
    Gotcha. (keep in mind, i understand how diodes work, just don't know proper diagramming techniques) The side with the bar (|) is the cathode. Cool - so i flip the diode and the LED's and that would be proper. Thanks!
    Unfortunately, my trial of SmartDraw expired, so that's that, I guess...
  6. #136
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    Well, I hate to do it, but I have to revive a very old thread back from the dead
    I made the circuit described in this thread, and it all works flawlessly. I used three 2200uf caps, and it gives me two minutes and thirty-two seconds (2:32) worth of time before it shuts off the relay.
    But, my issue is my inverter. When everything is plugged in, and I start my car, my inverter cant handle the crank very well, and my computer doesnt get passed the bios (post) screen and it locks up cold.
    So what I need to do is make a delay of about 4 or 5 seconds before the circuit gives power to the inverter. That way the car will be fully started before everything kicks on. That would solve my problem. But, I dont know how to do that
    Does anybody have any ideas or insight on how to fix this?
    I greatly apreciate any help or comments... Thanks In Advance!
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
  7. #137
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by we87 View Post
    Use a timer on the input to the 30-amp relay... Lots of info about them out there on the web. Some of these circuits might help. You're looking for one with an output of OFF, time delay, then On... I'm sure someone's diagrammed that somewhere. http://home.cogeco.ca/~rpaisley4/LM555.html
  8. #138
    Nov 2005
    Dallas, TX
    I found a power on delay circuit with some caps and resistors, but for some reason it doesnt work like the description reads
    http://ourworld.compuserve.com/homep....htm#delay.gif
    Can anybody give me some advice on how to use this? I wired it in, from what I understand, to be the right way, and it only works for about a half a second. When I used a bigger capacitor (6800 micro farad) the delay is about 40 seconds. I wired an LED to test and see the power delay output, and the LED doesnt turn on and off like I think it should. It turns on but verry sloowly... And slowly turns off.... Is that the way it should work?
    Thanks in advance for any advice. I apreciate it.
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
  9. #139
    Jun 2004
    Hi Mate,
    Did you make the circuit diagram with corrections as posted by lexanite (i.e. the 03-09-2006 10:30 PM post)?
    Cheers,
    Scott.
  10. #140
    Nov 2005
    Dallas, TX
    Quote Originally Posted by the_realscott View Post
    Hi Mate,
    Cheers,
    Scott.
    Yep, sure did. Like I said the shutdown works perfectly, but I need a delay of some sort.
    I ended up fixing it all. I used the start up delay I posted above and used that on a trigger relay that powers the shutdown controller...
    Now I have Key>5 Second Delay> PC Powers Up|Take Key Out>Inverter Stays On For A Few Minutes>Computer Completely Shuts Down>Inverter Dies
    All is perfect, and working very well...
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
  1. Voice control for Winamp
    By VoodooVoice in forum Software & Software Development
    Last Post: 08-01-2006, 05:19 PM
  2. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 11:21 PM
  3. Replies: 3
    Last Post: 05-26-2004, 04:08 AM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
