Page 7 of 16 FirstFirst 12345678910111213141516 LastLast
Results 61 to 70 of 154
Thread: Ghetto Startup/Shutdown Control for Inverter
  1. #61
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Quote Originally Posted by Curiosity
    Yep. You can do that too. I think it's earlier in the thread. Just do resistor & cap pulse on the PC power button when the ACC goes on, but also use 2 diodes to get input from the PC 12V as well, so it doesn't pulse when you turn the key off or on while the PC is on.
    ACC-->|-----cap+resistor--relay--power button
    PC --->|--/
    got a schematic possibly? I'm a visual person....
    TIA
  2. #62
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Me too. Something like this...
  3. #63
    Jun 2004
    Can't you just set the BIOS to start the computer on power failure? Then, whenever the PC is supplied with power to the power supply, it will turn on. Oh, that assumes that your BIOS supports that feature.
  4. #64
    Registered User Nicorolla's Avatar
    NB,Canada
    well this is nothing new
    Schematics/Pin Outs/Diagrams
  5. #65
    Mar 2004
    Florence Yall, BFKY
    My BIOS doesn't support it. I got jipped.
  6. #66
    Jun 2004
    Quote Originally Posted by Nicorolla
    Nobody said it was anything new... I was asking if my diagram was right, because I used your diagram, and a diagram from two other people, to combine it into one. All I'm looking for is advice on whether I have it right or not.
    Cheers.
  7. #67
    Feb 2005
    Barrie Ontario
    yea, and i'm finding that it won't power on automatically when running with an inverter. a buddy of mine built a regulator an is running 12vdc into his and it powers up automatically....
    I think i may jus stick with a button to power it on, especially with the colder weather on it's way. I wanna start letting the car warm up before i go turning stuff on lol
  8. #68
    Feb 2005
    Barrie Ontario
    Ummmm, so, i went to wire up a switch to test the generic UPS and it didn't work. I took a wire from Pin 8 (+5v) to a switch and one from Pin 4 to the other side of the switch, and got nothing at all. So, i decided to test my com port to see what pin i was getting voltage on, and I tested all of them and only got one wire with +12v, and one with -12v and nothing else...I'm stumped here
    I believe it was pin 7 that had +12v and I can't remember which had the -12v. I'd really love to see this work......
  9. #69
    NB,Canada
    you need to take 5v -> switch -> pin8
  10. #70
    Feb 2005
    Barrie Ontario
    I got it to work using a 5v line from an old AT power supply i had lying around, cause i didn't wanna open up my carputer yet again. I already have a 12v line out of the case, can i use it, or is 12v too much??
  1. Voice control for Winamp
    By VoodooVoice in forum Software & Software Development
    Last Post: 08-01-2006, 06:19 PM
  2. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-26-2004, 12:21 AM
  3. Replies: 3
    Last Post: 05-26-2004, 05:08 AM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
