Page 8 of 16 FirstFirst 12345678910111213141516 LastLast
Results 71 to 80 of 154
Thread: Ghetto Startup/Shutdown Control for Inverter
  1. #71
    Registered User Nicorolla's Avatar
    NB,Canada
    12volt is too much, i suggest you open up ur carPC and wire up the 5v from your power supply. It will be well worth it
  2. #72
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    okies. i guess i'll run more wires LOL. That's a tomorrow project tho
  3. #73
    Oct 2005
    surrey bc
    doesnt work
    dosent work ibuilt it and nothing just a relay
  4. #74
    Oct 2005
    surrey bc
    Angry ok i have the solution for laptops and desktop shutdown controller
    i figured it out and i still have got one response to any of my posts
    i might post my findings but i want to see if there is any resposes.
    my solution uses other peoples designs but i have made some changes and improved the design so if you want to see ask johhnyrotten@hotmail.com or here
  5. #75
    NB,Canada
    which one did you build?
  6. #76
    Sep 2005
    Quote Originally Posted by johnnybbad
    my solution uses other peoples designs but i have made some changes and improved the design so if you want to see ask johhnrotten@hotmail.com or here
    You would make my week if you would post it here. This is the biggest PITA thing I have left to do on my carpc, and your ideas thus far have been really good.
  7. #77
    Oct 2005
    surrey bc
    are u using a laptop or a desk top i will draw the schematic
    are you using a laoptop ?
  8. #78
    Oct 2005
    surrey bc
    vettjock
    i am going to post tonite
  9. #79
    Jun 2004
    Yeah, I'd really love to see your solution to this one as well. I had a go at building it from the schematic I put together, but it doesnt work... well, half of it works, i.e. the first relay, but the second one doesnt. My electronics knowledge is not sufficent to troubleshoot it.
    Scott.
  10. #80
    Oct 2005
    surrey bc
    Ok Here It Is I Have A Lot Of Pics But Here You Go Any Questions Ask
    HERE IS THE CIRCUIT ROUGH BUT YOU WILL GET IT I HOPE THE FIRST RELAY STARTS THE INVERTER FROM THE IGNITION AND THE SECOND ON THE SAME SWITCH STARTS THE INVERTER FROM THE USB OR ANY FIVE VOLT (FIVE VOLT RELAY ) THEN I HAVE A MOMENTARY RELAY (RESISTORCAP RELAY 12V )THAT TURNS ON THE COMPUTER WHEN THE INGNITIN IS TURNED AND THE FOURTH RELAY TURNS THE COMPUTER OFF WHEN IT LOSSES 12 VFROM THE CAR IT SHORTS 4, 8 PIN ON 9 PIN COM SO NOW I CAN SHUT OFF THE CAR AND THE COMPUTER WILL STAY RUNNING DUE TO THE FACT THAT THE RELAY FROM THE USB STAYS ON UNTILL THE COPUTER SHUTS ITSELF OFF ANY PROBLEMS EMAIL ME JOHHNYROTTEN@HOTMAIL.COM PLEASE I WILL HELP YOU FIGURE IT UOT I CAN ALSO SHOW HOW TO DO THE SAME WITHOU A LAPTOP USING A DESK TOP
  1. Voice control for Winamp
    By VoodooVoice in forum Software & Software Development
    Last Post: 08-01-2006, 05:19 PM
  2. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 11:21 PM
  3. Replies: 3
    Last Post: 05-26-2004, 04:08 AM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
