Page 9 of 16 FirstFirst 12345678910111213141516 LastLast
Results 81 to 90 of 154
Thread: Ghetto Startup/Shutdown Control for Inverter
  1. #81
    Jun 2004
    but this one doesn't have a delay timer to shut down the computer, does it? I mean, if your computer hangs on shutdown, then it will never turn off the power, and the battery will go flat right?
  2. #82
    Sep 2005
    And I'd love to see a desktop diagram. This is a good start, and I am willing to risk my PC not shutting down if I have to.
  3. #83
    Jun 2004
    Yeah, I need the forced-shutdown... The non-forced shutdown has been posted before.
  4. #84
    Oct 2005
    surrey bc
    shutdown hanging
    ok well i have realized that problem im thinking of just running software that if there is no movment of the mouse or keyboard for lets say 3 hours then the computer will automaticaly shut down using a forced shut down i havent set that up yet but i have the power on working i will post more detailed pictures when i have time
    one last thing I HAVE FORGOT TO PUT ONE PART ON THE SHEMATIC I HAVE A DIODE ON THE POSITIVE 5 VOLT LINE FROM THE COMPUTER TO THE RELAY
    I AM GOING TO DRAW A VERY GOOD SCHEMATIC FOR BOTH I HAVE A LOT OF PICS I WILL POST IF ANY ONE HAS A SUGGESTION OF A SOFTWARE THAT WILL TIRN IT OFF AT A CERTIN TIME
  5. #85
    Oct 2005
    surrey bc
    The Shorting Of Pins 4 8
    Then Pins 4 8 On The Com Port Turn It Off Thae Hangig Isue Would Be A Software Thing
  6. #86
    Oct 2005
    surrey bc
    Diode
    Heres Where The Diode Goes
  7. #87
    Jun 2004
    Quote Originally Posted by johnnybbad
    Yeah, but that still wont solve the problem if the computer hangs - because nothing will respond. You cant have a software solution to the problem, because the software will hang with the PC. That's why I tried to build the hardware one with the capacitor-resistor-transistor setup. That way, no matter what happens, after 90 seconds the power is totally cut off from the whole system (even the inverter)... but I couldnt get it to work.
    You should be able to get the computer to shut down at a particular time using the windows task scheduler in the system tray.
    Cheers,
    Scott.
  8. #88
    Nov 2005
    NSW Australia
    Quote Originally Posted by the_realscott
    Give me a day or so to draw it and I'll post my circuit diagram for you guys.
    It works perfectly....
  9. #89
    Jun 2004
    Ok cool.
    I think Johnnybad's circuit would be good, but I also need the forced shutdown... Does yours do that too?
  10. #90
    Oct 2005
    surrey bc
    Talking time delay relay
    http://www.macromatic.com/literature...l/compact.html
    try thi s but as far as my circut goes i just wanted to show the two relays to that same switch but if you were that concerned the relay from the 5 volts (usb) could be used ti triger the time delay relay that i have shown to shut the comp off
  1. Voice control for Winamp
    By VoodooVoice in forum Software & Software Development
    Last Post: 08-01-2006, 05:19 PM
  2. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 11:21 PM
  3. Replies: 3
    Last Post: 05-26-2004, 04:08 AM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
