Results 1 to 8 of 8
Thread: No power output on Opus
    Low Bitrate Vandyll's Avatar
    MD
    We did the install on my PC today, ran all the wires and hooked up the Opus 90W per the diagram. It seems to be getting power in fine (as shown on a volt meter), but doesn't power up the machine. Did a test on the pins on the output, and seems to be none to very little voltage going out. Any ideas?
    Last resort is running an inverter tomorrow, but I was so looking forward to running it from the Opus.
    2000 Monte Carlo SS - CarPC FINALLY INSTALLED!!!
    CarPC: VIA EPIA-M10000, Xenarc 700TSV, 20G 2.5" HD, Opus 90W, Targus USB DVD/CD-ROM
    Audio: Audigy 2 USB, Alpine 4 Channel Amp, 2 x Alpine 300W 6x9, 2 x Alpine 200W 6.5 (sub coming soon)
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    What does the green light on the OPUS do? The flash codes should tell you what's wrong with it.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    MD
    didn't see them doing anything. that's the problem. think we might have figured it out with something I found in another thread (switching the power switch cable so green is on the other side). gonna try it tomorrow morning and see if that works. I'm hoping that's the problem.....
    otherwise, it's back to the drawing board.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I'm not sure about the 90W, but on the 150W there is a flashing LED on the Opus itself. It flashes to give you status. As long as you have the +12v and ground hooked up, the LED should light up.
    MD
    I'm on my way back down to try it again. Should have web access this time, so I can do some online research if necessary. Thanks guys.
    MD
    We inverted the power switch wire and it fired right up. Sound from the Audigy2 is going through an Alpine 360W 4chan amp and 4 alpine speakers. Sounds really nice, but I need to find a way to get some more bass into the sound.
    Thanks for all the tips guys.
    Aug 1999
    Washington D.C.
    Glad it worked out. The diagnostic LEDs are really handy.
    MD
    Quote Originally Posted by Zip-Lock
    Yeah, now I just need to read up on Hibernation mode vs Standby vs Shutdown. All in all though, I am very happy with the system.
  1. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
  2. Opus is the only power supply that...
    By sunkistzzang in forum Power Supplies
    Last Post: 05-19-2004, 08:52 AM
  3. Opus 90w Shutdown Power off Porblems
    By antimatter in forum Power Supplies
    Last Post: 04-15-2004, 12:24 PM
  4. How much power does OPUS take up?
    By XxAndyxX in forum Power Supplies
    Last Post: 03-31-2004, 12:54 PM
  5. Where can i buy these Opus Power Supplies?
    Last Post: 01-14-2004, 11:44 AM
