Results 1 to 10 of 18
Thread: Whining/Ground Loop
    Constant Bitrate ZenerDiode's Avatar
    Nov 2003
    Bay Area
    Whining/Ground Loop
    argh...I'm getting the dreaded alternator whining. I've sanded the grounding area to a bright shiny sparkle, so I'm sure there's proper contact with the car chassis. My amp is definitely grounded well as I get no whining/hissing when I'm in CD or Tuner mode. But as soon as I switch my head unit to Aux-In mode...I hear that ever so faint whine. My amp and my opus are grounded in seperate locations and grounding them at the same spot isn't logistically possible. Would a "grounding distribution block" help? Any other devices to isolate the whine and kill it?
    Oct 2003
    Toronto, Canada
    Measure the resistance at the grounding points. Going by theory, you should only ground devices that have resistance differences of no more than 0.25 ohms to avoid ground loops.
    In theory a grounding distro block would eliminate that, but you said it yourself, it's not possible in your case? i'm guessing they're too far away from each other?
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Make sure that you didn't accidentally put a screw into an RCA cable, or something like that. You say grounding your amp + Opus isn't possible... Try to connect a wire between them as a test to kill any differences in potential. Interesting article wrote about ground loops:
    http://www.epanorama.net/documents/g...op/basics.html
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    is everything grounded to the same points? Also try to ground your computer case or motherboard to that same point
    '98 Explorer Sport
    80% done
    Nov 2003
    Marietta, GA
    THIS got rid of my alternator whine.
    MikeH
    Dec 2003
    Surrey, BC, Canada
    and ^^"that"^^ will also cause loss of sound quality. It's a bandage to the problem, not a solution. Best thing is to ground everything to the same point. I don't see how it can't be possible (wires can be bought fatter and longer), but if it is, the resistance explanation above makes a whole lot of sense and is probably a good rule to go by.
    Nov 2003
    Marietta, GA
    Bobby,
    I think you may be confusing ^^THAT^^ with THIS , which DOES affect sound quality. The noise filter I referred to is connected to the DC input line to your audio amp and/or CarPC and has no affect on the audio except for filtering incoming noise from the power lines.
    MikeH
    Nov 2003
    Bay Area
    thanks for the input guys. actually, I CAN use a distribution block I. I reason I couldn't ground the opus to the same place the amp is grounded is because I put the amp in a while back and basically, that area is inacessible. I mean I could totally tear up the carpet and spend about several hours messing with my seats and their adjustable rails. anyhow, thanks for the info...it'll give me some things to try out this weekedn.
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Hey Mike,
    I was going to ask you to recommend something for me. Did you put one on your PC power and one on your Amp power or how specifically did you wire them up?
    Peter
    Quote Originally Posted by MikeH
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
    Nov 2003
    Marietta, GA
    Chut,
    Here's what cured my noise problems. It took a nose filter on the +12V line and a ground loop isolator on the RCA auido lines, as well as good grounding techniques.....
    MikeH
  1. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  2. VB Code for Dan Harrison's OBDScan
    By Zip-Lock in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-21-2004, 12:21 AM
  3. Ground Loop
    By Twiek in forum General Hardware Discussion
    Last Post: 03-12-2004, 01:20 AM
  4. Turtle Beach Santa Cruz Sound Card GIVES me a ground loop?
    By rmjjensen in forum General Hardware Discussion
    Last Post: 11-15-2003, 08:26 AM
  5. FS: Ground Loop Isolator /w connectors
    By Cliff in forum Classified Archive
    Last Post: 07-08-2002, 01:08 AM
