here you go! http://www.roshanindustries.com/carmp3/sdc.htm
hi guys,
im a complete newb on the carpc seen, hence the name, but ive got a question about using standard psu's.
ill be building my pc under a false floor in the trunk, with lots of cooling fans etc, but because i wont be restrained to a certain size i would like to use an ATX board with a decent CPU, gfx card etc etc. So, my question is, can I use a standard PSU, and if so how? I know ill need an inverter to convert the 12v feed to 240v (UK) but how do you control the startup and shut down functions ala Opus?
cheers
correct, u could also use the ITPS, u can get it from linitx.com, they are based in the UK. Sounds like your going for the exact setup i have.
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
ive heard about inverters causing noise when it comes to using fm modulators or something. ill be running the sound straight into my amps, so will it cause a problem, what is yours like?
