if you gonna let it get power from psu .... why not buy a self powered one .... one that works off the usb 2.0 power from mobo .. (that inturn gets it from the psu ) .... so .. seems kinda useless to get it from the same source
I couldn't find one.. Can you post a link for one of these "self-powered" ones?
Anyhow, it's too late.
What I did so far was hack off the 120vAC adapter head, and wired up some terminal clips to hook into the +5v molex adapter to get power from the PSU's +5v rail. Do you think this will suffice? I don't see how it is different from using the 120vAC adapter which ouputted +5v....
Kevin
You should be fine. Just remember that each USB port on your hub is rated to 500mA by USB spec. Then add 500mA for some space. So a 4-port USB 2.0 hub needs 5V up to 2.5A regulated. Check your power-supply to make sure there's plenty available on the +5V rail.
i heard (dont know if its true or not) that the hub that is self powered from the mobo splits the power (500ma) between each port....Originally Posted by Q_gamelogic
rebuilding carpc... kinda..
The USB port on your mobo isn't required to provide more than 500mA. So if you plug in a 5-port bus-powered hub, it has to split up this 500mA among its ports. This won't be enough if you have several high-powered devices plugged in.
You did the right thing by buying a self-powered hub and wiring it directly into your +5V rail.
Here is a really article on self-powered vs. bus-powered hubs: http://www.microsoft.com/whdc/system/bus/USB/hubs.mspx
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
Acctually I think Powered USB hubs can get up to 6As per port...I think the 500mA spec was on USB 1.x only. When USB 2.0 came out I think it was raised.
According to section 7.2 of the USB 2.0 spec at http://www.usb.org/developers/docs/usb_20.zip a single USB device can consume upto 5 unit loads. A unit load is defined as 100mA.Originally Posted by Defiler
Sorry, was thinking USB Plus power...Originally Posted by rando
http://www.usbpluspower.org/
+5V @ 6A's. 6 amps down 20 Gauge USB wires.
Sounds like fun!![]()
