Results 1 to 10 of 19
Thread: opus 150 - battery flattening protection
    May 2003
    UK
    does the opus 150 kill power when the car battery drops below a certain voltage - i accidently left the update mode ( ignition wire high even with no ignition ) and came back to a completly dead battery - not even central locking worked.
    so either im mistaken and it doesn't have protection or I have a dodgy unit?
    James
    www.digital-car.co.uk - The UK CarPC Forum
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I've found that the low voltage protection is set too low to be able to start the car again. I believe this is because the units main purchasers are people like the Police, where being able to use the computer is more important than being able to start the car.
    There was a thread a few months back regarding changing the low voltage detection level, not sure what the outcome of it was though.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Confused
    That's not what it says in the manual though, is it?
    Aug 2003
    Essex, England
    Quote Originally Posted by Laidback
    Good point!
    The "used for police" thing was something i picked up from around here, so shoot them if they're wrong
    But I have found that it has kept the computer running and the engine won't start
    Garry
    www.aimee.cc
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    That's great, it's more important for the police to use the computer to find out where you are being murdered than for them to be able to drive there.
    Oct 2003
    Madrid
    Quote Originally Posted by Enforcer
    More likely finding out where you last got a speeding ticket or something, I'm not sure murder is very high on their list!
    May 2003
    UK
    hmm ok the manual states it shoudl - it can't have powered down though it used ALL the juice, no locks, no lights, I couldn't even turn ignition on - pc must have run untill it crashed at 7v ish when the opus can't give out 12v anymore
    Need to check this in an artificial test somehow, not sure my variable power supplies have enough power....
    James
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Throw a couple of diodes on your 12v line in front of the opus. That should drop the voltage below 11v for you. Then just wait and see if it shuts down, or not.
    May 2003
    UK
    very good idea just make a switch between straight 12v and the diodes - should be able to set a lower voltage - either that or I run carpc off a little lead acid battery with a multimeter and see if it cuts out below 11v
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    not the same question but a similar one, the 90w model states that you can set a jumper to have it cut the power after the pc has shut down. this is not true of the 150w model though??
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  2. Battery dead in car. Opus?
    By Chairboy in forum Power Supplies
    Last Post: 05-13-2004, 01:06 AM
  3. opus 150, how long will it run on battery
    By beaverpants in forum Power Supplies
    Last Post: 03-12-2004, 08:14 PM
  4. Wiring Opus directly to battery, please help!
    By touser in forum Power Supplies
    Last Post: 02-08-2004, 01:38 PM
  5. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 03:44 PM
