Results 1 to 7 of 7
Thread: opus150w - wont go into hibernate in OS
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    im testing my system (Epia-M10000+Opus150W+WindowsXP) out of the car right now and its not working right
    i startup the computer with 12v and ignition on the 12v from a ac-dc power supply and the ground obviously on ground
    the computer starts up fine
    but, when i remove the ignition line, the computer stays on (i have the jumper off the opus board so it should turn off in 10 seconds from removal of the ignition line, but it doesnt)
    i have noticed though that if i disconnect the ignition line while the computer is not inside windows yet, it will turn off in the specified 10 seconds
    i set windows for that when the power button is pressed, it should go into hibernate
    i set the bios to POS1
    im stumped, any help?
    thanks
    edit: now it just randomly shut down (not hibernate or standby, the power just cut)
    then 5 seconds later it just powered back on (cause all the cables were still hooked up)
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Try setting the BIOS to S1&S3, that worked for me.
    If it just shut down then started up again automatically, try starting the car, cos when that happens to me, I can't start the car and have to jump-start it
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Jun 2004
    I have the same problem with my setup,
    Travela c134 case, m10k m/b, itps and tank circuit.
    when i start the car the pc boots up after 5 secs, when i turn the car off it shutsdown straight away, but if i set it to hibernate from the power switch the pc wont do it and shutsdown completely.
    I also have the problem of just turning itself off when driving, at no set time, its just random, its as if i just pulled the power, so i checked the voltage out of the itps and noticed the output drops to 10.2v sometimes just for a second and i think this is causing the pc to fail.
    The only way i can think of fixing it is to bypass the voltage regulation on the itps because it loses 1.1v through the regulator and i only have 13.25v going in.
    May 2003
    Texas
    Are any of you guys running the new Itunes? version 4.5 and sometimes even 4.2 and between will NOT go into hibernation if Itunes is playing a song.
    Also, tripple check your ground wire. Sometimes the PC will still come on and run with a faulty ground connection. Mine got loose and the PC was starting up and shutting down randomly.
    I ran my opus power trigger wires to the motherboard along with the case power supply. So when I was having problems with the PC, I would hit the power button manually, if the computer still didnt shut down I know it is a software or motherboard issue. If the computer DOES shut down then I know its the Opus PS.
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    Ok, your problems is likely with windows, you need to tell windows wot to do when u press the power button (essential wot yr opus is doing). Do the following:
    Display properties, screen saver tab, Power button, Advanced tab, and select hibernate when you press the power button.
    If thats not it, then it could be bios settings or incorrec polarisation on your motherboard connector.
    HTH
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Mar 2003
    Rohnert Park, CA
    Quote Originally Posted by no1knows
    HTH
    i said in my first post that i already did this
    i also tried setting the motherboard to S1&S3 but I got the same problems
    Mar 2003
    Rohnert Park, CA
    ive narrowed down the problem
    while booted into windows, i hooked up a normal push button power switch
    when its pressed, windows should go into hibernate....but it doesnt
    i tried setting it to standby when the button was pressed....nothing
    so the problem lies in the operating system, the opus is doing exactly what its supposed to
    now what would cause this though?
    edit: nm, fixed it
  1. The Os and The Car
    By SjLucky in forum Software & Software Development
    Last Post: 06-24-2004, 02:09 PM
  2. My computer won't hibernate
    By Mtlca401 in forum General Hardware Discussion
    Last Post: 02-13-2004, 09:39 AM
  3. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 09:11 AM
  4. my opinion as Linux as an OS for carputing
    By churnopol in forum Software & Software Development
    Last Post: 05-05-2003, 12:56 AM
  5. Which OS?
    By accord in forum Software & Software Development
    Last Post: 11-22-2001, 08:22 PM
