GND is also referred as "common" both of those wires go to the same point, they are used just to distribute the load a bit, as to not get to much current on one single GND wire.
On a molex power connector on a computer power supply there is 5v+, 5v-, 12v+, and 12v-. I was wondering why have two grounds? Can't 5v+ and 12v+ both uses the same ground connection?
'96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
'00 Jeep Wrangler - planning stage
What can BROWN do for you?
Dont confuse a ground for -12v because they are not the same. There are two grounds because of wire guage. Lets say the power supplies cable could only carry 1 amp before catching fire. If your device uses 1 amp on the 12v line and 1 amp on the 5v line, then try to ground through only 1 wire rated 1amp, you will be up a creek.
