Originally Posted by
Ormo
Voltage isn't so much the issue with electrocution. Current is. 0.1A (100mA) is enough to cause fribulation (heart palpatations) and, thus, death. Your car battery can probably put out upwards of 100A.
The good thing is that your skin is high resistance, the result is that when the 12V is applied across your skin, usually you will get a shock, but no serious damage as not enough current passes through your skin. However, it is still best to be careful, you can get serious burns if you earth an unfused live from the material you short it with heating up. And you can also get burns from small scale electrocution.
But to be safe, basically, if you are working on something, use one hand and ensure you are not earthed to the car chassis. If working with a trailing live wire, make sure it is fused, and if doing any work on major electrical systems that are not fused or have very high ratings, disconnect the battery first.
