Results 1 to 10 of 11
Thread: ATX PSU shocked me!!!
    Constant Bitrate ashbosh's Avatar
    Mar 2004
    Well, I was trying to test my 4 yr old 150W atx psu with the carpc setup. I connected it to the pc, it booted and was working fine. When I touched one of the heat sink to see if its getting hot., I got a nice electrical shock!!!. I checked with my multimeter and it showed around 700V when the pc was on and around 170V when the pc off shut off. I may be bit off on the volatges,but the heatsink definately had some current passing thru. I disconnected the power cord and the voltage was gone. The question is .. is this normal??? I thought the heat sink should be isolated.
    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
    Holux G210
    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    I've done it too man lol. Except with caps, and it took a little while to let go .
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Mar 2002
    Tucson
    Bad assumption, always check them with a meter first. Many manufactures mount Power components directly to an isolated heatsink for better thermal conductivity. Of course; like yourself, I found that out the painfull way.
    Walt
    http://www.safossils.com/mp3car.html
    Mar 2004
    My brain got reset in the process. I can think clearly, better than before now
    Holux G210
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    A few rules to 'live' by when dealing with unknown powered circuits.
    1) Assume everything is live.
    2) Assume nothing.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    Quote Originally Posted by rando
    2) Assume nothing.
    rule number 1 is voided by rule number 2.
    -Mars
    Feb 2004
    Elmira NY
    normal everyday thing
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Marsupial
    See the smiley?
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    You said you measured 700V on the ATX casing, what was this referenced to?
    Is your inverter floating?
    Jun 2002
    Malaysia
    hehe i was shocked with that too.. it was for a max of 0.5 secs before the MRCB tripped.. but it felt like a whole minute..
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Opus ATX and ITX PSU - Difference?
    By phoTToniq in forum Power Supplies
    Last Post: 09-22-2003, 04:21 AM
  3. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  4. AT / FULL ATX PSU FOR SALE
    By Mastero in forum Classified Archive
    Last Post: 01-09-2002, 01:54 PM
  5. ATX PSU from m2pc.com / to jjohnson
    By r0cket- in forum General Hardware Discussion
    Last Post: 12-20-2000, 03:00 PM
