Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Thoughts on an ITPS Override Switch
  1. #21
    Variable Bitrate wkolodny's Avatar
    Quote Originally Posted by STI_FFY
    DPDT W/center-off. The three examples I gave are precisely this type, You just would not have used the second gang in the previous example (now you will use it).
    Cool. Thanks. Got any resistor/diode recommendations/Specs?
    Don't Fear The Gurkey
    Click here to check out My Setup
  2. #22
    Constant Bitrate STI_FFY's Avatar
    New Market, MD
    Quote Originally Posted by wkolodny
    Most any LED will do, biggest decision will be what size and mounting style you want to utilize. There are panel mount types at RS also.
    Their part # 276-068 for example, has a forward voltage of about 1.8V.
    ~13.8V-1.8V = ~12V the resistor must drop.
    This LED will tolerate 20mA, so the formula to determine optimal resistor value for maximum brightness is 12V/20mA = 600 Ohms. Resistors aren't readily available in that value, and lower value = higher current and is less tolerable so next common value of 670 Ohms is about right. A 1K would work fine, but be a bit less bright (12V/1K=12mA). Less bright might be a good thing depending on how you mount it.
    I'd recommend experimentation with several types to find the right orientation and brightness. There's nothing more annoying than a "laser beam" lookin' LED in the eye when you're driving.
    Don't forget to spec the power dissipation of the limiting resistor. 20mA X 12V = 240mW. This would be tolerable for a 1/4 watt resistor indefinitely. If your chosen LED is much brighter and requires more current, you may have to go to 1/2 Watt resistor.
    SeeYa! -Jim-
  1. My 2001 Sport Trac Install
    By wkolodny in forum Show off your project
    Last Post: 01-30-2008, 11:18 AM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  3. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
  4. ITPS and PW-70: What turns it on?
    By dug1967 in forum Power Supplies
    Last Post: 02-15-2004, 08:22 AM
  5. Help With Extending Laptop Docking Station's Power Button
    By JeffesonM in forum General Hardware Discussion
    Last Post: 04-14-2003, 02:13 AM
