Results 1 to 10 of 12
Thread: Getting power into Opus
    Jun 2004
    Ok, so my Opus arrived this morning, albeit with a minor problem.
    From what I can see on the Opus website you get power into it from the 3 pin connector, the one thats a little like a molex. Problem is I aint got one in the package.
    Can some one clarify if that is the lead needed to supply power?
    cheers
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    Which OPUS PSU did you get? 90W or 150W.
    Jun 2004
    150w
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Yep, you need power in on those three cables.
    Call up whoever you got it from, and say that you didn't get one, i'm sure they'll send one out ASAP.
    Then, check all the packaging and eventually find it, then call up supplier and tell them to not send it out, as you found it
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Jun 2004
    got it off ebay, and the guy aint replying to my emails, barsteward
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Well you could always take it apart and put on a different connector. Also, look up the instructions for the Opus (around here somehwere). I believe the part number for the connector is listed.
    Jun 2004
    ill have a look-see for the instructions/part numbers, where do i get it from then though?
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    If you can, take a picture of the connector and somebody might be able to help you.
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    if you get desperate you can solder bare leads right on the pins
    Mar 2004
    Redondo Beach, CA
    It's probably a molex part. www.molex.com. If they won't sell it to you direct, they can probably tell you who will.
  1. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  2. Will a 150W OPUS power this?
    By mbkowns in forum Power Supplies
    Last Post: 04-14-2004, 03:17 PM
  3. Power my Opus?
    By sfay93 in forum Newbie
    Last Post: 03-18-2004, 12:27 AM
  4. Opus 90w Power Action
    By EBoundEE in forum Power Supplies
    Last Post: 03-10-2004, 10:11 PM
