Results 21 to 30 of 35
Thread: Will leaving Windows in Standby drain battery?
  1. #21
    Feb 2004
    Los Angeles
    i installed the latest non-Beta Lilliput driver and the PC went into Hibernate mode just fine.
    Grayscale - Yes, Hibernate mode is essentially the same as powering off the PC but there will always be some amperage draw from the mobo, mine just happens to hog up a ton of juice. =\
  2. #22
    Feb 2004
    Los Angeles
    Quote Originally Posted by cadence117
    so do most people use hibernate with their carputers?
    and then how can you get the opus to send your carputer into hibernate whenever it shuts off.
    although I don't have an Opus yet, I believe you go into your Display Properties->Screen Saver->Power->Hibernate->Enable.
    Then choose When I press the Power Button do the following: Hibernate.
    Please correct me if I'm wrong.
  3. #23
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Quote Originally Posted by hifiguy
    Yes, it will go into hibernate fine. But not standby right?
    CarPC install is starting to come along again...
  4. #24
    Feb 2004
    Los Angeles
    i'll try it tonite 'n post the results.
  5. #25
    May 2004
    Arkansas
    Alright. Make sure you try to do it in standby S3, not S1. Also, does anyone know where I can get the beta drivers? Hifiguy what version are your drivers? Could you send a link?
  6. #26
    Feb 2004
    Los Angeles
    So I put my PC on standby in the middle of playing an mp3 and found the following:
    Watts consumed: 35
    CPU remains on
    Wifi pci remains on
    USB 2.0 hub remains on
    Mouse LED remains on
    Coming back from standby took under 1 second (freshly formatted machine) and music continued to play even before Lilliput came on!
    If it wasn't for the 35W drain I'd definitely used Standby over Hibernate.
  7. #27
    May 2004
    Arkansas
    35W/12V=2.91 Amps? Geez...maybe you could try to set the BIOS so that nothing wakes up standby except power button...then maybe it wont power the USB devices and stuff. I think I could keep my computer on standby over night though.
    Now did you do this in S1 or S3 standby? How did you measure how much current was being drawn? Or watts...
  8. #28
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I measured 2 amps...
    2 amps is hella lot I draw 1.5 watts when the computer is in S3 standby (suspend to ram) and 1 watt when the computer is completely shutdown / hibernate which is like .083 to .125 amps.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  9. #29
    May 2004
    Arkansas
    Yeah...thats what I was thinking. I don't think its right...do you think you could measure for me what it draws in S1?
  10. #30
    Feb 2004
    Los Angeles
    I measured 2 amps when the PC is in Hibernate but this will really depend on your motherboard.
    measure Watts consumed
    Whoah! my mistake...it's 2 Watts instead of amps.
    I'm using a device called Watts Up? to measure the Watts/volts/amps used by my AC Enermax 350 PSU.
    I'm not sure which S-mode the motherboard was using, I can check the various modes and post results tonight, maybe S1 will draw very little! FYI, Hibernate mode takes me about 6 secs tops to boot.
    I'm using driver vers 3.2.1.2925 but here's where the beta drivers are: http://www.egalax.com.tw/Download.htm
    gaphix.com
    MSI KM4M MicroATX, Duron 1.6, 512 Micron 2700, WD 80 7200 8mb, Pioneer 120S, M-audio 7.1 pci, Targus USB 2.0 hub, 3com 11a/b/g pci, PNY FX5200 AGP 64mb, Lilliput 7"
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 11:45 AM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  3. S1 Standby Power Consumption Drain Battery?
    By Grayscale in forum General Hardware Discussion
    Last Post: 06-16-2004, 02:30 PM
  4. Problem with tank battery - any good Plan B?
    Last Post: 06-14-2004, 09:10 PM
  5. Replies: 1
    Last Post: 02-06-2004, 04:44 PM
