Check the specs on the inverter, it probably has an input operating range that will tell you exactly what it will tolerate. 9 volts is more then likely too low. The same thing applies to the lilliput, however, there probably won't be any damage done to it, it will just turn off by itself.
LinkBack URL
About LinkBacks
