Results 1 to 5 of 5
Thread: Can I use an old power supply?
    Jun 2004
    I have some old power supplies from Mac LC475's kicking around and I'm wondering if I could use them with an inverter to power a modern motherboard.
    The specs (I need explanations of what they mean cause I'm a newb) are:
    output of +5V at 3.75 A, -5 at 0.075A, and +12V at 0.78 A.
    input of 100-240V, 50-60 Hz, and 1A.
    Thanks !
    Constant Bitrate STI_FFY's Avatar
    New Market, MD
    Quote Originally Posted by purple_car
    Thanks !
    Most modern motherboards need an ample 3.3 Volt rail. This seems to be absent from the specs you listed.
    SeeYa! -Jim-
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    looks like a 30 watt PSU. and yes, you will most likely need the 3.3v rail for the modern ATX mobos. so its not going to work for ya, i dont think.
    rebuilding carpc... kinda..
    Jun 2004
    wicked, thanks for the help. So how do you tell it is a 30W, and how do you tell if a PSU has a 3.3 volt rail. And what exactly is a volt rail.
    Thanks for the help.
    Nov 2003
    CT
    if it doesnt say 3.3v anywhere...it doesnt have the 3.3v rail.. to get the wattage you do (volts * amps = watts) so (5 * 3.75 = 18.75) plus whatever the 12 volt rail came to. if i remember it was under 30. but now that i think about it, that might be low. the INPUT to the PSU says 100-240 @ 1 amp...which would be 100-115 watts in america (at 100% efficiency) so at say, 30% efficiency, it would be 30 watts. which seems low. im actually pretty tired. lol...hmn..i think i'll try this again in a few days when my brain isnt fried (i have finals tomorrow and am going away for the weekend).
    does the PSU say anything about total watts on it?
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. 350 watt power supply
    By MasterJacko96 in forum Power Supplies
    Last Post: 01-20-2004, 05:01 PM
  3. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 06:36 PM
  4. at power supply
    By Ice9 in forum Power Supplies
    Last Post: 03-02-2003, 05:19 AM
  5. power supply question
    By perlmax90 in forum General Hardware Discussion
    Last Post: 12-08-2000, 12:16 AM
