Page 10 of 32 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 316
Thread: Mastero MK-4.5 250w 12v DC-DC ATX PSU + SDC
  1. #91
    Constant Bitrate Juliemac's Avatar
    Upstate NY
    Turns out my ISP has blocked all .tk due to the RIAA and Spam complaints.
    I hope he is well after the disaster.
    I would still like to buy a machine from him.
    Julie
  2. #92
    FLAC Mastero's Avatar
    Aug 2001
    India
    Hey dont worry i am fine just been busy with work..... My site is fine
    try this if your .tk is blocked HERE
    Enjoy
    Mastero
  3. #93
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Is anyone int he UK building one of these as i wondering what the part availablity was like if i went for the semi kit or would it just work out easier )and cheaper) to get the full kit as i suspect?
    Cheers, Andy
  4. #94
    Mar 2004
    Bristol
    1 more thing, when i click ont he 4.5 semi kit detaisl i get page not found. I am going through the .com site as i have trouble with the .tk one too.
    EDIT: opened the parts list and saw the items in red are not included int he semi kit
  5. #95
    Jan 2004
    some more questions
    1. i'm assuming the led next to the standby is the standby indicator :P, what is the other led (next to the 47uh inductor)?
    2. atx-1 plugs into the motherboard's power pins?
    3. where are the 5v, 3.3v, 5v standby, -5v, -12v outputs?
    edit: found the -5, -12, is the 5v standby the one just labelled "STBY"?
    4. where does the "power on/good" signals come from?
    edit: are they "PG" and "PS_ON"?
    5. where does vcc come from?
    thanks a lot
  6. #96
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    some more questions
    You are correct on the first one. The one next to the inductor is the power on indicator (PSU full on).
    Plug ATX-1 into the mobo power switch. Then the header from the power button switch plug to ATX-2. Basically you are rerouting the power button switch.
    3.3V is below MAX788 chips (3 holes), and 5V is below MAX787 (9 or 10 holes)
    5V standby is label with STBY.
    Power Good (Gray) = PG - below CMOS 4049 chip
    Power ON (Green) = PS_ON - Between 12V relay and Sproggy relay.
    What is Vcc? If you are talking about power in put, +12V In = Battery Red.
    If you talking about ACC. That is going to the car keyswitch (Only on/hot when the key is insert and turn.). Cig lighter is one of them.
    thanks a lot
    You are welcom
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  7. #97
    Jan 2004
    Quote Originally Posted by MatrixPC
    i was following the atx diagram from mastero's diy page, here:
    http://www.roshanindustries.com/mp3p...ges/atxpin.jpg
    thanks again mate
    edit: btw, would you know if the max787 and national lm2678t-5.0 are comparible? (i.e. could i use the national chip instead, i can't get my hands on the max787s)
  8. #98
    Sep 2003
    Beach City, Socal
    Vcc on that diagram is the 5V (Orange).
    If you want to build one base on National LM3678 chip, look for Mastero/Sproggy 4.0 thread. Some people report problem with those chips. That is why later Mastero change the board to use Max chip and called it 4.1 (I think). They are similar but not an identical replacement (7pins V 5 pins).
  9. #99
    Jan 2004
    does anyone have a copy of the 4.0 component placement pdf?
    edit: found a copy
  10. #100
    Jan 2004
    finally finished building it! (and the max chip decided to arrive today )
    but now testing it, the 5v line under no load comes up as around 8v....... any ideas?
  1. Mastero MK-4 ATX PSU with features.
    By Mastero in forum Power Supplies
    Last Post: 08-23-2006, 07:49 PM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  3. Mastero MK-4 ATX PSU Semi kit for SALE
    By Mastero in forum Classified Archive
    Last Post: 06-10-2004, 01:42 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 10:03 AM
