Page 2 of 32 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 316
Thread: Mastero MK-4.5 250w 12v DC-DC ATX PSU + SDC
  1. #11
    FLAC Mastero's Avatar
    Aug 2001
    India
    Matrix i know this cuircut .... i have also tried it works great.
    Let me see if i can add a startup also ...
    Mastero
  2. #12
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Cool, it's always good to see you considering more features Mastero. You the man!
    BTW, if you use the ignition/ACC signal for the switched +12v lead then wont this circuit send a pulse every time the key is switch from off to on (even if the computer is already on)? Suppose you have a large shutdown delay to keep your pc running during stops at a gas station. When jump back in and restart your car, your computer is going to receive a pulse and start to shut down, isn't it?
  3. #13
    Tainted Love Cris's Avatar
    Romania
    How much heat is that PSU going to dissipate?
  4. #14
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Rando, that is true. Everytime you have the IGN/ACC line come hot the circuit send a pulse. That is why on the bottom of my previous post I stated that the (+) to the relay coil is connect to the Sproggy relay output.
    Now this got me think more that could also be wrong since the Sproggy relay won't turn on until the power button is "pushed".
    The correct place to connect to is the the relay where the output is going to the 5V standby regulator (base on MK4.0) The SDC circuit switch on the relay (STBY Relay) to put the PSU in standby mode thru a 5V regulator chip. The output of the (STBY relay) can connect to the (+) coil of this "power on" relay.
    Ok now it should work.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #15
    Mar 2004
    Redondo Beach, CA
    Oops, I didn't notice the latter part of your post. With the changes you posted, it makes sense now. Also, it seems like you might be able to ditch the relay in favor of a much smaller and cheaper switching transistor. Small, cheap, powerful and efficient ... it's going to get there!
  6. #16
    Aug 2001
    India
    I am working on it guys its going positive...
    cheers
    Mastero
  7. #17
    Aug 2001
    India
    Planning on putting a delay start up so the pc will start after the car is cranked..
    cheers
    Mastero
  8. #18
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I thought your power supply survived the crank, so why do you want to delay the start of the pc.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  9. #19
    Aug 2001
    India
    Quote Originally Posted by Quattro-A4
    Imagine cold start .. early morning ..?? cranking cranking cranking ... battery is already loaded with car pc so the battery has that extra load on it ..
    I feel its better if there is a delay of 10 sec.. for those cold early morning start and those diesel cold start
    Mastero
  10. #20
    Dec 2003
    New York
    I didn't think of cold starts.
    Installed
  1. Mastero MK-4 ATX PSU with features.
    By Mastero in forum Power Supplies
    Last Post: 08-23-2006, 07:49 PM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  3. Mastero MK-4 ATX PSU Semi kit for SALE
    By Mastero in forum Classified Archive
    Last Post: 06-10-2004, 01:42 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 10:03 AM
