Page 4 of 32 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 316
Thread: Mastero MK-4.5 250w 12v DC-DC ATX PSU + SDC
  1. #31
    FLAC Mastero's Avatar
    Aug 2001
    India
    Quote Originally Posted by MrPerfectionest
    Has the supply been tested fully loaded, ie. with all rails delivering their rated current for X amount of time?
    I have not tested the PSU .. been busy ..
    Sent the prototype PCB for making shall test it this week.
    Please check if you find any erorrs in the design.
    measures 170mm x 110mm (just 25mm more than mk-4 in width)
    as for the low batt shutdown no space .. maybe in the next version.
    Cheers
    Mastero
  2. #32
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Mastero, Great work. My only question is will the Sproggy relay support that much power? The highest I can find is 12A or 16A. Unless you are using a different one than those of previous version.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #33
    Aug 2001
    India
    Good point matrix .. Will check it out. anything else
    Mastero
  4. #34
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Mastero, any idea when the next version will be out. I'm starting my project now and still new a power supply. Also any idea what the price might?
    Thanks.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  5. #35
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    nice work mastero!!
    Will there be a kit for this version?
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
  6. #36
    Jun 2004
    Cool Parts list?
    Maestro,
    Could you post a parts list for the 4.5 PSU? I can't speak for others, but I find it very hard to make out all the parts and numbers from the pcb graphic.
    David
  7. #37
    Aug 2001
    India
    shall make one soon ...! Shall have a kit for this version also
    Cheers
    Mastero
  8. #38
    Jun 2004
    Thanks Maestro
    I don't need the kit, just the partslist. I like building the project myself. Already got the PCB making stuff and all the relevant links I'll need.
    Thank you for the great work.
    David
  9. #39
    Jun 2004
    Talking
    I made my own list of parts. I doublechecked it for omissions but I could have missed a part or two. It has all the chips you need to order though.
    David
    P.S. Maestro, could I use vertical Inductors versus the horizontal ones you have in your PCB layout? I was thinking vertical might get a little more airflow.
    Attached Files Attached Files
  10. #40
    Aug 2001
    India
    You can use any as long as its as per the specs
    Mastero
  1. Mastero MK-4 ATX PSU with features.
    By Mastero in forum Power Supplies
    Last Post: 08-23-2006, 08:49 PM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. Mastero MK-4 ATX PSU Semi kit for SALE
    By Mastero in forum Classified Archive
    Last Post: 06-10-2004, 02:42 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 11:03 AM
