Page 1 of 32 1234567891011 ... LastLast
Results 1 to 10 of 316
Thread: Mastero MK-4.5 250w 12v DC-DC ATX PSU + SDC
    FLAC Mastero's Avatar
    Aug 2001
    India
    Mastero MK-4.5 12v DC-DC ATX PSU + SDC
    Hello Friends.
    MK-4.5 is comming soon....
    Specification:~
    Input
    8vdc ~ 30vdc (Can survive a Diesel motor start)
    Output
    +5vdc @ 12A (max)
    +3.3vdc @ 12A (max)
    +12vdc @ 10A (max)
    +5vstby @ 5A (max)
    -5v @ 500MA (max)
    -12v @ 500MA (max)
    PCB Size: 170mm x 110mm (wont fit standard atx psu case)
    Built in shut down controller.
    Shall post details soon..
    Cheers
    Mastero
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Sounds interesting. Keep up the good work!
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    250 watts sound impressive. Do you know what the cost might be?
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Dam 250W that is impressive good work
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2003
    New York
    Mastero,
    Just wondering if you had any updates on the MK-4.5
    Installed
    Is this gonna be another brute force attempt?
    By the time you get to a 400W supply the heatsink will need to be about 1 ft x 1ft
    Aug 2001
    India
    Quote Originally Posted by MrPerfectionest
    No there will not be a 400w supply ....
    It shall be a while before testing....about a week or two...
    Mastero
    Dec 2003
    New York
    Thanks for the update. I'm just wating to buy a power supply ans a gps receiver before I start the installation.
    Installed
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Wow, nice specifications, how is the shutdown controller going to work? will it be PIC based? also, how will this be avaliable? thru a kit or just schematic?
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Sep 2003
    Beach City, Socal
    Mastero, just a suggestion for the next PSU.
    Can you add another component to the PSU that can send a pulse to turn on the PC. Right now we depend on the mobo that "Resume on power loss" for turn on. Most mobos have that option but there are some mobos don't have that option.
    I found the circuit from the12volt.com that use a relay, cap and resistor for constant to pulse.
    - Output of the Sproggy relay connect to Pin 86 on image (relay coil +).
    - Ground connect to the cap and resistor then to Pin 85 on image (relay coil -) .
    - 2 terminal of the ATX power sw can be connected to pin 87 and 30 on image (SPST-NO) pin of the relay.
    I tested that circuit on my mobo and it work very well.
  1. Mastero MK-4 ATX PSU with features.
    By Mastero in forum Power Supplies
    Last Post: 08-23-2006, 08:49 PM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. Mastero MK-4 ATX PSU Semi kit for SALE
    By Mastero in forum Classified Archive
    Last Post: 06-10-2004, 02:42 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 11:03 AM
