Results 1 to 5 of 5
Thread: What's powered by -5V?
    FLAC Gutter's Avatar
    Dec 1999
    Casina, Italy
    I picked up a tiny (5W x 4D x 3H) 120W powersupply from Goodwill just a little bit ago noticing that it didn't have a -5V pin. What components (on-motherboard or peripheral) use -5V?
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    nothing much anymore. Its left over from the original PC and I have heard of it being used once or twice in a sound card but your chances are good that you can run fine without it.
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    I think -5V is used on the old ISA bus, and not used very often any more.
    Apparently the -12V is used for serial ports, and not much else either.
    Oct 2003
    -5v is not used at all. Nethier is -12v on modern motherboards.
    The RS-232 serial port drivers (built into the southbridge these days) on pretty much all motherboards today create their own -12v.
    I've seen some very cheap off brand boards even go wthout -12v at he serial port. Instead of swinging +12v (binary 1) to -12v+ (binary 0) they go +12v (binary 1) to 0v (binary 0).
    Fortunately most serial port equipment is very forgiving and will accept 0v as binary 0.
    Dec 1999
    Casina, Italy
    Thanks for the answers, guys.
  1. Solved: USB bus stays powered after shutdown
    By S4Per in forum Power Supplies
    Last Post: 05-28-2007, 10:09 PM
  2. Need more 5v....
    By sq_geek in forum Power Supplies
    Last Post: 05-13-2004, 06:53 PM
  3. What if power is 4.3 not 5v
    Last Post: 04-07-2004, 07:35 PM
  4. Looking for a 5V Controller for LQ104V1DG11
    By SuperMatty in forum LCD/Display
    Last Post: 08-03-2002, 12:06 AM
  5. need help on -5v power
    By noproblem in forum General Hardware Discussion
    Last Post: 07-11-2000, 12:37 AM
