the way mine set up is this...
i opened my inverter, and solder the on/off switch to constantly on...
then buy 30a relay from radio shack or autozone....
assume u have a cd head unit with an amp...
there is a blue or aux wire coming out from headunit to power the amp...
tap in the line to go to 86 on the relay...
30 on the relay to 12v car battery
55 is ground
87 is to your inverter...
and ground the - inverter and - on the relay to the same spot...
so i control my power on/off from my cd headunit...if the cd is off, everything is off...
hope this..help...
do a search for more details...
my topic about this is not long ago..
icet...
LinkBack URL
About LinkBacks
