Recently I've noticed that the power line on the OPUS is getting extremely hot. I have 8 gauge running directly from the battery to the power connector that comes with the OPUS. The 8 guage doesn't seem hot at all, it's when I connect it to the like 12 gauge or so connector that came with the OPUS is where the problem begins. The white connector on the wires is also turning brown, from the heat I presume. I have a fuse on the 8 guage right before it connects to the OPUS and I measured my power draw with a multimeter and I'm only drawing 7 amps through the power lines.
Has anyone else experienced this problem and how can I fix this? Would replacing the 12 gauge wires going directly into the OPUS with 8 help and if so why doesn't the OPUS come with a lower gauge then?
Also, for some reason, my computer no longer survives crank. It use to stay on just fine when starting the car, now whenever I crank it, the computer stays on with fans and everythign buzzing, but it starts beeping, the display goes blank, and nothing works anymore.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
You should stop using the Opus till you figured whats wrong...
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
150 WattOriginally Posted by Zip-Lock
Yes, DEFINITELY STOP USING IT until you figure it out. If it's getting hot enough to cook the connector, it's hot enough to start a fire.
Thanks for the replies, but I already know that hot things cause fires, but stop using it is not really a solution to my problem... Any other suggestions.
hmm, send it back?
[B]Any time you get a "brown / hot" connector it simply means that you have a loose connection. This could be pin to pin or wire crimped into pin OR BOTH. It will get hot because there is visible or non-visible arcing whithin.
You must repair the connection = problem goes away. As well, when a connection is not secure it is not possible to draw full current unless the two fuse together (cannot be removed) hence the overheating of a minute connection - there are not enough electrons pressent to foreward the flow of current - not enough surface area. This means you will also drop voltage which is why you have a drop out when starting the engine. You are pulling current but because of the bad connection the voltage goes down during cracking.
Sorry dude, I just had ugly visions about a burned up G35 on the side of the road.Originally Posted by god_of_cpu
2nz's post looks promising.
