Results 1 to 7 of 7
Thread: 300W Inverter, only works so often
    Newbie spaced_chris's Avatar
    Nov 2003
    Newcastle, UK, England
    I've got a 300W inverter powering the PC in my car. The only time the inverter powers up my computer is first thing in the morning when I havent' used the car for about 8 hours.
    If I drive off somewhere, get back into my car, switch on the engine, the computer will not power up at all. This happens all the time and does my head in. Its as though the battery has used up a lot of power when i've been driving that there isn't enough to power up the computer? I have even tried turning on the inverter after i've started the car, incase the surge from the engines causes the inverter to go into a 'safe mode' so to say.
    Why is this the case, does anybody have any ideas? I'd be grateful for anyones help.
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    Cant think of anything other than possibly dodgy inverter/heat. Sounds more likely to be the inverter being dodgy. Does it get hot?
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Is the inverter wired directly to the battery, or are you using a cigarette lighter? What gauge wires are you using? What make/model inverter do you have?
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    check the voltage of the battery when the engine is running, maybe your alternator is going bad.
    Nov 2003
    Quote Originally Posted by no1knows
    It does not seem to be too hot. Just normal I'd say
    Quote Originally Posted by dodgetimes2
    Yeh the inverter is wired directly to the battery. Will act dumb here, but what are gauge wires? lol The inverter I bought was a 300w from maplins for about 20. Will have to check out the make/model.
    Feb 2004
    ive got the 150W one from maplins, it was getting very hot and beeping, but now ive chucked a fan on it. Havent had any reliability issues other than that however.
    I'd say u had a dodgy inverter.
    Nov 2003
    I think you could be right. Its just weird how it only comes on when I haven't used the car for a while. I just thought that it might be going into some safe mode?
  1. Does a 300w PSU need a 300w inverter?
    By Max018 in forum Power Supplies
    Last Post: 03-24-2004, 11:53 AM
  2. CarPC and monitor on 300w inverter?
    By bombboyer in forum General Hardware Discussion
    Last Post: 12-29-2002, 06:49 AM
  3. 300W power inverter on EBAY!!!
    By gqmd in forum Classified Archive
    Last Post: 08-13-2001, 11:51 AM
  4. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
  5. Laptop inverter works in a desktop pc?
    By prado_sergio in forum General Hardware Discussion
    Last Post: 10-11-1999, 09:56 AM
