Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Arise PSU problem!
  1. #11
    Mar 2004
    Det, MI
    I have the same problem with my Aries. It will power up the PC sometime but most of the time it will hang at the post screen. Sometime it will get as far as yours and I get the black screen too or it will load xp and hang. When I boot with the inverter everything work fine. Hope some find a solution to your it may also help me too.
    1999 Explorer 70%
    SN41g2 AMD 2000xp
    Lilliput 7" TS & 2-5" lcds
    40Gb & DVD laptop drives, 160Gb HD
    XM & Xtreame (FM) radio
    GPS, PowerMate
    SB live PCI, Stand alone TV tuner
    4ch & Explorer Sub amp
    Aries 150w PSU (n/working)
    400w power inverter.
  2. #12
    Maximum Bitrate mobileh1's Avatar
    San Francisco
    I have called Arise and they have escalated the problem, hopefully they will find a solution. NoPiston is probably onto something because its right after windows starts the network that the problem happens. I bet you'll find safe mode without networking will boot for you.
    If/When I get this working I'll post the results...
    .//Daren
    (Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
    MediaCar/CoPilot7/Routis
  3. #13
    May 2003
    MA
    Some things I learned will I had my Arise up and running:
    1. Watch out if you are not using a ITPS or equivalent it will drain you battery
    2. If using a ITPS you must bypass the voltage regulator, or the Arise will not detect the proper min voltage to turn ON
    3. I had all the same problems with the system half starting.... what worked for me was turn of AC and all unecessary acc. stuff and rev engine
    4. System did not survive crank using a Arise
    5. For what it is it's to big....
  4. #14
    San Francisco
    I've got an opus on order from the store here, give that a try...
    .//Daren
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  2. Need help + Arise PSU notes
    By jusatry in forum General Hardware Discussion
    Last Post: 03-16-2004, 09:02 PM
  3. hooking up my arise PSU....?
    Last Post: 03-13-2004, 07:53 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  5. Question: Arise psu: ground, neg, and pos.....?
    By Tony S in forum Power Supplies
    Last Post: 05-02-2001, 07:54 AM
