Results 1 to 4 of 4
Thread: PSU needs grounding?
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    Im getting interference from my PSU out of my speakers, is this because my PSU case is not grounded?
    is that a stupid question?
    CarPC status: iPod, 3,456,217 songs so **** you
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Not a stupid question, I had the same problem and saw Confused grounded his case and all was well.
    However I checked my case and the whole thing was already grounded, and the resistance to ground was as low as it could be for the ground wiring - I ended up using a ground loop isolator and it sorted everything in seconds.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Jul 2004
    Brazil
    On my first system, with an inverter & ac psu, when I first turned the system on on the car, I had a REALLY loud buzzing on my speakers, and the PSU was under the passenger seat while the computer was under the dash and the amps were in the trunk! I found out that the ground pin on the inverter ac outlet was connected to nothing. When I connected it to the car chassis (effectively grounding the psu case) the buzzing went away completely. That means to me: always ground the psu. However, it won't help to cure alternator whining, that one is a lot more complicated...
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by Motoko
    I just came inside from repairing mine!
    Yes, I grounded the psu straight to a good ground.
    Also, run your sound wires as short as possible and as far away from the power wires as possible.
    Mine came out great, completely quiet. (Other than music)
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  2. Arise PSU problem!
    By mobileh1 in forum Power Supplies
    Last Post: 06-25-2004, 10:14 PM
  3. hooking up my arise PSU....?
    By jusatry in forum General Hardware Discussion
    Last Post: 03-13-2004, 07:53 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  5. mircoATX PSU?
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 03-12-2001, 02:30 AM
