Results 1 to 10 of 15
Thread: Auto-dim Lilly
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Auto-dim Lilly
    I just read the thread on regulating a low 12v to make it 12.6 to get a nice bright lilly. Seams simple to throw some more risistance in the circuit and make it dim... perhaps a rheostat or something.
    My truck, like many new cars, has auto-sensing headlights. That is, they come on when its dark. the sensor (for my 2004 GMC Canyon) is inside near my instrument cluster (or so I've read.) When the headlights are on, the internal lights dim. How hard can it be to tap this, perhaps with a relay or something? You could add a simple switch to bypass it in the even you want a bright LCD with lights on.
    Thoughts?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Jun 2004
    Under the radar
    I am also interested in something like this...
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    Want to build your own?
    If you are intersted in possibly building one:
    Can anyone design me a lilliput regullator?
    shchua's post on, and the others around, "05-24-2004, 11:58 PM" should help!
    Jun 2004
    Massachusetts
    Quote Originally Posted by GruvThang
    Thats the thread that got me thinkin...
    ,./(0)3
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    There were other threads about putting a 100 ohm potentiometer in series with the 1 ohm resistor that powers the CCF inverter as well, and how that would shorten the life of the CCFL. I don't know if that's because of the lowered Hz on the output? It seems to work well though, except if you turn it on in the day time and forget it's dimmed. I thought I broke it!
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    LDR is the acronym of the day... Light Dependent Resistor
    Mar 2004
    Florence Yall, BFKY
    I have some photocells. Is that the same thing? Only problem is they range from like 500K to 1M so I couldn't figure out how to convert that to 0 - 100 ohms, or even 0 - 50 would work. I'm a software guy so this is too much for me.
    Jun 2003
    Fairfax, VA
    hmm, you could maybe put another fixed resistor in series with it.
    Jun 2004
    Massachusetts
    There must be a way to wire it into the car's auto-headlight system...
    ,./(0)3
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    of course u put a relay inline with the switch line that turns the lights on. no?
    CarPC status: iPod, 3,456,217 songs so **** you
  1. Replies: 36
    Last Post: 04-13-2005, 05:03 AM
  2. 7" dscustoms lcd auto turn on?
    By icet in forum LCD/Display
    Last Post: 05-14-2004, 12:48 PM
  3. Dim Lilliput 7"
    By dw_uk2000 in forum Input Devices
    Last Post: 03-23-2004, 04:27 PM
  4. Auto dimming LCD
    By cproaudio in forum Software & Software Development
    Last Post: 01-06-2004, 01:43 AM
  5. Winamp auto start of visual plugins!
    By Norman in forum Software & Software Development
    Last Post: 03-10-2000, 04:05 PM
