Results 1 to 5 of 5
Thread: Can a factory alarm command the OPUS to power down?
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    I've got a 1998 Grand Prix GTP with a factory Alarm, without Onstar. I was curious if anyone has any experience with the alarms on these cars? I was wondering if there was a way to use the factory Alarm & keyfob to signal the OPUS on or off?
    Jul 2004
    Minneapolis
    Well, I'm new to the whole carputer thing and don't know the specifics of what you need to trigger the OPUS on and off but I can tell you a bit about your car's factory alarm. Your alarm arms itself off of the lock wire which is a light blue wire in the driver's kick and the alarm disarm wire is orange/black also in the driver's kick. Supposedly it is in a 32 pin plug and is pin# 5. Both of these are negative triggers and probably not high current so I would assume you'll want to use relays to change that signal over to whatever the OPUS needs.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Yes, this is possible I did it with my car:
    http://g35driver.com/forums/showthre...age=&view=&sb=
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Jul 2004
    Minneapolis
    I have modified the relay setup from god_of_cpu's car to work w/ yours seeing that you have negative trigger locks and his are posi. Sorry if it's copyrighted god_of_cpu. Also, I would recommend getting your 12V+ @ the ignition harness (red or red/white) or if you're ok going through the firewall straight to the battery. Just remember to use a fuse and a DMM to verify wiring.
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I have been requesting something like this from the people with electronics knowledge over at www.my350z.com (they have some G35c stuff there too if you haven't been there) and all I got was responses about how hard/impossible it would be.
    Hopefully the Z is not too different, and I can get something like this to work for me.
  1. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:14 PM
  2. Using 12v plug for power to OPUS???
    By slffl in forum Power Supplies
    Last Post: 03-18-2004, 02:31 AM
  3. Power my Opus?
    By sfay93 in forum Newbie
    Last Post: 03-18-2004, 12:27 AM
  4. Where can i buy these Opus Power Supplies?
    By antimatter in forum Power Supplies
    Last Post: 01-14-2004, 11:44 AM
  5. Replies: 5
    Last Post: 01-08-2004, 12:38 AM
