Results 1 to 2 of 2
Thread: Opus 150 and Athlon XP?
    Low Bitrate philstuf's Avatar
    Jul 2004
    Georgia
    Question Opus 150 and Athlon XP?
    Does anyone have any experience running an Opus 150 watt PS with an Athlon XP 2200 (Or higher speed Athlon XP)? I currently have a Via M-10000 as my car PC and want to speed the little guy up by swapping in the athlon and motherboard. I was wondering if the Opus 150 really had enough juice to keep the athlon XP up and running. I have the Athlon system just lying around and wanted to put it to good use.
    For anyone wondering about the extra hardware load, I will be running a single 3.5" hard drive, Asus motherboard, Geforce 4 MX (cheap bastard that I am ). There will be a couple of USB powered devices hooked directly to the motherboard (XMPCR, D-link DSB-R100, Deluo GPS). The DVD-Rom, USB hub and SB Audigy will all be powered from a separate regulated source and will not load the PC's power supply.
    I do not currently have the Opus, and wanted a little feedback before I purchased.
    Thanks in advance,
    -Phil
    1995 Thunderbird
    Clarion 9375 HU, 2X CDC1255 12 Disc changer, 7500 DSP/EQ/Xover (w/fiber optic interconnects), 7501 TV Tuner/Aux
    Xtant 1001d 1 Ch, 4180c 4 ch
    7" Xenarc VGA touchscreen
    1GHz Via-Nehemiah, 250 GB HDD
    XMPCR w/TOSLink, SB Audigy NX
    Newbie racerdude's Avatar
    Apr 2005
    Athelon XP
    I am using a Atelon XP 2500 but underclocked the frontend bus to 100Mhz instead of 166(keep it running cooler in the summer) I have a USB slim CD drive and a 2.5 inch 30GB hard drive(3.5 inch can not handle the Gs in a gar especially the way I drive...) and everything else built on MOBO. It works file for me. Although I had to replace my previous 3.5" HD because it started getting bad sectors.
  1. 150 Watt Power Supply
    By DoDaDDy in forum Power Supplies
    Last Post: 06-20-2004, 05:46 PM
  2. OPUS 150 with athlon 1ghz?
    By aznblueeboi in forum Power Supplies
    Last Post: 04-05-2004, 02:12 AM
  3. Is 150w Opus enough?
    By kai445 in forum Power Supplies
    Last Post: 02-21-2004, 03:30 AM
  4. Can the OPUS 150 W support this setup?
    By kiztope in forum Power Supplies
    Last Post: 01-14-2004, 11:45 AM
  5. WTB: Opus 150 (Or trade for my 250W Keypower)
    By SuperMatty in forum Classified Archive
    Last Post: 06-27-2003, 02:56 PM
