Results 1 to 6 of 6
Thread: ITPS won't hibernate
    Jul 2004
    I got the ITPS and it seemed to work ok but my computer would never hibernate correctly. I just noticed today that on acc off, the power to the computer is killed rather than the on/off circuit pulse and then power down 45 secs later. Is there something that is commonly done wrong or is this one acting goofy?
    Newbie Jointer's Avatar
    Nov 2003
    Bålsta, Sweden
    Quote Originally Posted by digglerd
    Have you configured your OS to Shutdown on "Power Button" ?
    If you are running Windows you can usually select if you want it to be "Power Off, Shutdown or Sleep".
    Jul 2004
    Yah the power button is set for Hibernate and the ITPS is supposed to give it 45 secs to do so after key off. It doesn't it powers down immediately after key off.
    Dec 2003
    Minnesota
    You must have it wired wrong then.
    Are you sure the acc is hooked up right? Because if you have it going into the power instead.. it will cut power as soon as the key is off. It also means that it is running off of your acc line, which may not have the power to run it properly.
    http://www.AJQuick.com/ - Fiberglassing Tutorials!
    My Cardomain Page - 1998 Dodge Neon R/T
    Jul 2004
    Red wire to battery
    White wire to acc
    black wire to ground
    Correct?
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    There are three wires running into the ITPS. Permanent 12V, switched 12V, and Ground.
    If you have the permanent and switched 12v round the wrong way, then it will cause the PC to turn off ungracefully as you switch off the ignition, as the ITPS is losing it's permanent 12V supply instead.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. ITPS-Auto Power Sequencer as Shotdown Controller
    By Nellor in forum Power Supplies
    Last Post: 03-16-2005, 12:24 PM
  3. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  4. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
  5. ITPS Power Sequence review
    By saito in forum The Review Palace
    Last Post: 12-18-2003, 10:26 AM
