Results 1 to 7 of 7
Thread: is my OPUS missing jumper pins?
    Feb 2004
    Los Angeles
    got my Opus today and there's a big hole on the top-right hand side. a small zip-lock bag included a single jumper but i don't see where to place it? is that hole suppose to be there?
    more pics
    gaphix.com
    MSI KM4M MicroATX, Duron 1.6, 512 Micron 2700, WD 80 7200 8mb, Pioneer 120S, M-audio 7.1 pci, Targus USB 2.0 hub, 3com 11a/b/g pci, PNY FX5200 AGP 64mb, Lilliput 7"
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    Shut Down Delay Timer Setup A four-pin jumper block (JU1) is located on the DC-DC power supply controller board, (top right side). The fan cover assembly must be disassembled to access the jumper block.
    4 3 2 1 JU1
    o o o o No jumpers installed: 10 sec turn off delay (jumpers are inserted in vertical park position- Factory default)
    o o o-o Pins 1 & 2 shorted: 20 minutes turn off delay
    o-o o o Pins 3 & 4 shorted: 40 minutes turn off delay
    o-o o-o Pins 1 & 2, 3 & 4 shorted: 60 minutes turn off delay
    Super Moderator xBrady's Avatar
    USA
    yes that hole should be there. To get the the jumper you have to open up the power supply and you will see where you can add the jumper.
    Installed.
    -GPSSecure- - GPS Tracking
    Feb 2004
    Los Angeles
    Quote Originally Posted by lawrence
    aha! missed that part, sorry!
    oh ok, so what's the real purpose behind the opening?
    gaphix.com
    USA
    Quote Originally Posted by hifiguy
    Because depending on your case the connector can be positioned in those two differant ways to fit your case.
    Installed.
    Feb 2004
    Los Angeles
    ahh, very smart feature. thanks.
    gaphix.com
    USA
    np
    Installed.
  1. Opus and BMW (e46)
    By captain_jim1 in forum Power Supplies
    Last Post: 01-20-2005, 11:46 PM
  2. Hot Hot OPUS!!
    By god_of_cpu in forum Power Supplies
    Last Post: 06-22-2004, 05:02 PM
  3. Replies: 8
    Last Post: 06-05-2004, 10:13 AM
  4. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 04:15 AM
  5. Where can I buy pins and jumper leads from?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 03-27-2002, 12:57 PM
