Results 1 to 5 of 5
Thread: do i need to modify the PSU?
    May 2004
    Northridge CA
    ok so i got a 350 watt inverter but it goes into overload when i plug in my 120 watt PSU. i dont even turn it on. right when i plug it into the inverter the inverter shuts down. the inverter just stops outputtin power and i cant get anything to work. however my Playstation 2 works fine off the inverter.
    even with just the PSU plugged in the inverter does not work.
    i think i read somwhere that i need to modify the PSU to get it to work but ive done searches since 6 this morning and nothing.
    please help me!!!
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    Me thinks you got a short somewhere, check your grounds on the PSU and PC, I think thats what the inverter doesnt like
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Quote Originally Posted by SAScooby
    Ditto. Something is possibly shorted out somewhere. Is the switch on the back set to 115v or 230v? Has this PSU worked ever? Is it new or used?
    ATVMS.com
    May 2004
    Northridge CA
    the PSU is set at 115.
    its farily new and it does work with my house outlets.
    ive also tried 2 other PSUs.
    bah hope someone out there has a solution.
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Probably a huge inrush current and the inverter cannot handle it
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  2. hooking up my arise PSU....?
    By jusatry in forum General Hardware Discussion
    Last Post: 03-13-2004, 07:53 PM
  3. Replies: 11
    Last Post: 02-24-2004, 03:29 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  5. mircoATX PSU?
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 03-12-2001, 02:30 AM
