Results 1 to 5 of 5
Thread: powering LCD off my opus
    Feb 2004
    Elmira NY
    ok i have a opus 150w
    im going to run a athlon XP 1700+ and 512 ram onboard video. 200gig hard drive 2 80mm fan's CPU fan. in the trunk
    up front im going to run a 15" desktop LCD monitor and a 52xCDrw.
    the 15" is ment to be run off 115v AC at 1.5amp
    but it converts it to 12v to power the actuly LCD.
    if my math is right at 12v thats 16amps
    alot more then a opus can push.
    should i use a DC/AC converter. or maybe find a high amp DC/DC 12v
    but then the screen will turn off during crank and the monitor wont.
    any idea's welcome
    FLAC Chairboy's Avatar
    Jan 2004
    It's actually probably a couple amps straight 12v. I have a Samsung 15" LCD and the power supply says it is rated to output 12V at something like 2 amps, and I'd think it's unlikely your 15" takes 10x power.
    Feb 2004
    Elmira NY
    the opus only has 5amps at 12 volts. would this be enuf?
    Feb 2004
    Elmira NY
    i just used a volt meater on the DC power to the LCD it draw's 1.8amp at 12v
    i havent tested it on my opus yet
    pke
    pke is offline
    Jul 2004
    Netherlands
    I tried to run my 12V 10.4” TFT from the Opus. I found the Opus could not handle the inrush current when I switched on the screen. You can read all about it in my post called limit inrush current (which is not solved yet by the way).
    I would be interested to know if you succeed with your 15” LCD on the Opus.
  1. PLVH 7.2" LCD [RCA / RGB]. please help. PICS =>>
    By Avner in forum LCD/Display
    Last Post: 05-07-2004, 11:08 AM
  2. powering LCD
    By [H]Bugster in forum LCD/Display
    Last Post: 09-27-2003, 03:39 PM
  3. Fs: Opus 150w / Epia M10000
    By streetpower in forum Classified Archive
    Last Post: 09-20-2003, 02:04 PM
  4. Powering LCD from PSU
    By Robb@E.P.E in forum LCD/Display
    Last Post: 08-16-2003, 11:31 AM
  5. Powering LCD
    By marsjell in forum LCD/Display
    Last Post: 03-09-2002, 11:29 PM
