While a 55 amp alternator is a bit on the small side for todays vehicles I think it should be fine. What it depends on is how much total power you are trying to use.(high powered stereo system, running heeater and defroster and headlights and so on all at the same time) Car are designed so th at you can run every thing all at once and not kill the battery. That being said they did not plan it out for us to add all the the other things we do. (carputers and such) A 55amp alternator is going to put out well over 700 watts. As long as you don't run every electrical device in your car at once for extended periods of time you will be fine.(I realize its unrealistic that you would anyway but just trying to make my point clear)
LinkBack URL
About LinkBacks
