Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: carputer shuts off after 30 seconds except when engine is on
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Just today installed my carputer
    Everything functions normally except that the computer will turn off (go into hibernate actually) after 10-40 seconds (seems random) when I dont have the engine on (only accessory power). Then 2-3 seconds later it comes back on and does the whole thing over again.
    When I turn the engine on, the computer stays on like it should
    My first guess was that it was the battery; not able to put out enough juice
    It's an Interstate
    PSU is an Opus 150W
    Any help is much appreciated
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by aoLhaTer
    It's an Interstate
    PSU is an Opus 150W
    What kind of system do you have?
    Installed.
    -GPSSecure- - GPS Tracking
    Mar 2003
    Rohnert Park, CA
    Epia M10000
    WD600BB
    1x256MB
    Belkin 54g PCI
    USA
    Epia M10000
    WD600BB
    1x256MB
    Belkin 54g PCI
    Hmm odd. Mine does the same thing but I think it is becuase I am drawing too much power. You aren't running much that would take a lot of power.
    Bytheway I hate AOL too. I work for MSN
    Installed.
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    i have an opus 150w too and it does the same thing. i put tested the voltage on the switched 12v line and when my engine is on it's right around 12 but when the engine is off it fluctuates between 11 and 12. i thought that was why it was doing it. this weekend i'm going to see what happens if i change my grounding location.
    Mar 2003
    Rohnert Park, CA
    I took a meter and tested both the accessory line and battery line
    they fluctuated but thats natural
    battery was 11.78 with computer off, 11.54 with computer on
    i thought maybe the opus was powering down the pc because it thtought the battery was below 11v (has built in protection)
    For power (12v batt and ground) I tapped off of the power antenna
    For 12v access I ran a 18awg line from my headunit to the trunk (was no access line in the trunk and didnt want to bother hunting for one elsewhere)
    Mar 2003
    Rohnert Park, CA
    i also had some problems with my turn signals where they worked sporadically, sometimes not at all
    last two trips theyve worked fine but at first it was iffy
    maybe it has something to do with my problem
    would it have anything to do with me using 18 gauge cable for 12v batt and ground? (its all i had)
    USA
    Doubt it.
    Installed.
    Mar 2003
    Rohnert Park, CA
    then wtf is it?!!?! arghhh
    san jose, CA
    I have the same behaviour along with another problem I posted. I guess I need to check my voltages too.
  1. Replies: 19
    Last Post: 12-04-2004, 05:37 PM
  2. Replies: 9
    Last Post: 10-23-2004, 02:25 AM
  3. Adding file syncronisation to Media Engine
    By skippy76 in forum Media Engine
    Last Post: 03-26-2004, 11:01 PM
  4. you guys run your carputer with the engine off?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 01-14-2004, 05:39 AM
