Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Secondary battery?
    Jul 2004
    Secondary battery?
    i want my carputer to stay on all the time, and just enter hibernate mode when the car is powered off. however, i don't want to risk the chance of the computer draining the battery and getting stranded somewhere. so i figured, why not just get a secondary battery. what im thinking is get another battery, and link the 2ndary using a battery separator. so that way, the carputer will run off of the 2ndary and if that gets drained, all that happens is the computer turns off. then next time i drive, the 2ndary will get recharged and should be set for another little while.
    does this sound like a good solution or are there other problems with it? will i need a more powerful alternator? has anyone tried this?
    Newbie BigRedBee's Avatar
    Jan 2004
    PDX
    I've done this, and so have many others. I've had limited success, and have had to replace my secondary battery (Optima Yellowtop) twice for some unknown reason that I'm still debugging.
    VIA EPIA M10000 | 7" Lilliput Touch VGA | PW70 | 256 Meg RAM | 20 Gig 2.5" drive
    Dual Battery with Optima Yellowtop | Hellroaring Battery Isolater
    ICOM 2720A| Delorme Earthmate GPS | Tiny Track APRS
    Survives Crank
    I can cut the power to my setup in hibernate mode, do you mean standby mode?
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    check this thread... Holy Fkkk I found hibernation..... if you can survive crank with an inverter once in hibernate you don't have any issues with the battery draining because the computer won't even see power if the inverter is off.
    Jun 2004
    isolator
    I have tried this using a nice big isolator, thing is, seems like I drop 2-3 volts using the isolator, and while driving with all my **** on, lights, AC and stuff it would kill my carputer. I just remvoved the isolator now and am running the two batteries in parallel mode and I have tons of voltage and works nice now.
    Jul 2004
    any reason why you'd wire it in parallel rather than series??
    Feb 2004
    Atlanta
    Running this in parallel is the wrong thing to do. Too much strain on the alternator trying to keep both batteries at the same capacity. Over time you will crap your alternator by doing this. Also if one battery is dead, both batteries are dead.
    FLAC Chairboy's Avatar
    Jan 2004
    Putting them in series will mean 24v, techijatt.
    New York
    right on the money of what chairboy said. if you do series, you'll just end up frying the electrical circuit at 24v. Can't do that, parallel only option.
    Newbie kingmissel's Avatar
    Mar 2004
    NY
    I have 2 batteries hooked up. Separate them by a Huge relay. I have a 200Amp Stinger Relay that connects the batteries in Parallel when the key is on. They disconnect from each other when the key is off. Then my main battery starts the car, while my 2nd battery was powering the PC for a few hours. Works great!
    -- kingmissel
    IN: P4 2.4Ghz Mini-Itx, 512MB Ram, Slot-load DVD/CD-RW, Opus 150w, 2nd Battery, JL Audio 500/5 amp, TouchScreen, GPS, Cell Internet Access, 802.11G
    Not IN:[I] FM Tuner, OBD-II
    Preview: temporarily down
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 11:45 AM
  2. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 04:43 PM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  4. Problem with tank battery - any good Plan B?
    Last Post: 06-14-2004, 09:10 PM
  5. Using Battery Charger in the House?
    By dug1967 in forum General Hardware Discussion
    Last Post: 05-14-2004, 10:55 AM
