Results 1 to 10 of 16
Thread: Power + shutdown controller Suggestions.
    Low Bitrate savante's Avatar
    Jul 2004
    Chicago
    Hi,
    I've read through many of the boards for a while now but haven't been a member too long.
    I finally think I've come to a decision as to what Im going to build my car computer around. Since Im not concerned with confined spacing(computer will reside in the trunk) and therefore heating issues, Ive decided not to go with an Epia based computer but instead build around this case: Shuttle XPC which includes a 250W power supply.
    After its built and configured the only added hardware inside the box other than CPU and Memory is a 2.5" laptop harddrive. I will have all my other components external.
    However, I am not too clear on the Power Supply/Shutdown controller topic. I'm assuming that because this case already comes with a power supply, I should just get the carnetix controller? Are there any heat/power issues using AMD based systems?
    Any advice would be appreciated, thanks.
    S.
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    remove the Shuttles 250w power supply and put an Opus in there, you wont look back
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by SAScooby
    It might extend your project out 6 months waiting for Opus and having to send your Opus back but right now it is the best power option IMO.
    Installed.
    -GPSSecure- - GPS Tracking
    Jul 2004
    Chicago
    Quote Originally Posted by brady
    6 months to get an Opus and having to send it back? Are they problematic and in short supply?
    Feb 2004
    I think just in short supply and read the Opus manual, will save you lots of headaches
    USA
    Quote Originally Posted by savante
    They used to be. Here's the story. When I first started the project Opus were out of their power supplies. I called and was told I would get mine in 3-4 weeks. I hadn't heard anything 4 weeks later so then I called again. He said another 3-4 weeks. 4 weeks later he said it would be another 2 weeks. 2 weeks later I gave him all my CC info so he could send me the the PS. 1 week after that, and after I email Opus again, I got an invoice that said they had shipped it. I received it a week later. Plugged it in. Found out after A LOT of work that it wouldn't support my CPU fully clocked because my MB didn't have the 12V 4 pin connector. I didn't mind having under clocked so that was no biggie. Then I found out it wasn't shutting my computer down. With weeks of calling them and having them tell me to try stuff I sent the PS back. I got a call rather quickly this time after they received the power supply. He originally wanted me to send my motherboard to them because they thought it was a compatibility issue but he said he would look into it. I called them back a week later and talked to Kris (the main guy). We talked for a little bit and then discovered there was a setting on my motherboard that was possibly causing the problem. He said he would test the PS out again and send it the next day. I received it, changed my motherboard setting and it has worked great since then.....
    Point is. I am the worst case scenario guaranteed. Just buy it from one of these stores that tests it out and you know have it in stock and you will probably be like most people and not have a single problem with it.
    Installed.
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    got my sff opus in three days no problems except thay sent out the wrong one first
    Jul 2004
    Chicago
    Thanks for all your replies guys, sounds like Opus is the way to go. As for the compatibility issue you had Brady, will the startup/shutdown/suspend functionality be fully supported by the Shuttle XPC I mentioned? What motherboard are you using?
    And what is the 12V 4 pin connector?
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    mp3car just got the opus specifically for shuttle pc's:
    http://www.mp3car.com/store/product_...e437bcfc918dbb
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
    Jul 2004
    Chicago
    Quote Originally Posted by vcbb5
    Connectors: 1-ATX, 3 HDD, 1FDD, P4 Header
    Whats the P4 Header and does it make a difference that this Shuttle uses an AMD Board?
  1. ITPS-Auto Power Sequencer as Shotdown Controller
    By Nellor in forum Power Supplies
    Last Post: 03-16-2005, 11:24 AM
  2. Startup pulse fix with Jeff Shutdown Controller
    By moahdib in forum Power Supplies
    Last Post: 03-03-2004, 11:51 AM
  3. Stuff for sale! (ezgo pc, pw70, zootjeff shutdown controller, IRMan)
    By 00CericaRuss in forum Classified Archive
    Last Post: 02-02-2004, 01:35 PM
  4. Yet Another Shutdown Controller Question....
    By Zac in forum Power Supplies
    Last Post: 02-02-2004, 12:20 AM
  5. why use a shutdown controller???
    By cyjad in forum Newbie
    Last Post: 12-04-2003, 04:49 AM
