Results 1 to 6 of 6
Thread: Fuse with Inverter?
    May 2004
    Question Fuse with Inverter?
    Hey guys,
    I was wondering what size fuse should I put inline from the inverter to the battery? It's a 375 WATT Inverter.
    FLAC Chairboy's Avatar
    Jan 2004
    Better question, what gauge wire runs from the battery to the inverter? The wire size is a better indicator of what type of fuse to put in. At 375 watts, you're looking at over 30 amps, but you want a. a margin of error and b. to match it to the wire thickness and length.
    May 2004
    Quote Originally Posted by Chairboy
    Hmm, I always thought it was the power you are drawing to determine the size of the fuse. Anyway, going to use an 8 guage wire I imagine. Also, it's going to run the length of the car to the trunk...So I think about 15 feet.
    Jan 2004
    For 15 feet, I think 8 gauge will be borderline for your 30+ amp draw, but it might be ok. At 15 feet, 8 gauge is rated at 30 amps. At 10 feet, it's rated at 40, so it depends on how much you actually use.
    May 2004
    So should I do like 6 Guage or something? What I don't get is that if the draw is that much, than why do they put dinky *** wires on the end that is supposed to draw out of the cigarette lighter? Won't this not make sense when the wire gets tiny when the bigger guage wire gets to the inverter?
    Actually come to think of it, why would they even allow a connection to be made through a cigarette lighter in the first place when there is potential for damage? This does not seem like a product that would last very long on the market.
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    i think the question was fuse size ---check what the inverter came with when it was new
    if you cant tell this link may help https://gullfoss2.fcc.gov/prod/oet/c...ericSearch.cfm
    just insert fcc id code from the back of the unit to find out who built it --and sometime thay have specs for the item
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  2. Help with inverter
    By Starkan in forum General Hardware Discussion
    Last Post: 07-10-2004, 06:43 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  4. FS:HYPERION Simplicity Series standalone Controller and inverter
    By kickercivic1 in forum Classified Archive
    Last Post: 06-25-2003, 09:01 AM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
